No precat y pipe
Old Jun 16, 2009 | 12:18 AM
87droptop's Avatar
87droptop
Default No precat y pipe
Is it worth the trouble to replace the stock (1987) precat y pipe with an aftermarket no precat pipe. I have already installed a high flow main cat (major pain in the ***). I don't want to install headers at this time, but I wouldn't mind a little extra umph.
Old Jun 16, 2009 | 01:50 AM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
I replaced the front Y in my 89 after I put in the Corsa exhaust. It sounded much better after the new front Y in. Just my .02 worth.
Kevin
Old Jun 16, 2009 | 02:09 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I replaced the precat Y on my 86 with an 85 nocat Y pipe.
The match between the main cat and Y was a problem.
My decision was that gutting the precats created a flow issue thru the cat housing. Also the factory Y is a dual pipe that helps to shield the heat from the floorboards.
I changed the front Y and Magnaflow cat and Borla catback at the same time so its hard to say if the Y was an effective change.
Old Jun 16, 2009 | 02:22 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
They(most vette supliers) sell a 86-91 pre-catless Y pipe that bolts in.Did you use a 85 specific Y pipe and had troubles with it?
I bought the catless Y pipe made for my 86 and it bolted in with no hassles or fit problems.
Less heat and the starters lasted longer.
Old Jun 16, 2009 | 02:27 AM
JrRifleCoach
I was looking for a dual pipe unit and the cost of used was better than new. Until I started the installation...
Old Jun 16, 2009 | 11:01 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I had a muffler shop cut off the pre cats and sleeve the pipes. Some shops may not do that. In my case there was a noticable difference in power and sound.
Old Jun 16, 2009 | 11:39 AM
Dolfan's Avatar
Dolfan
I just swapped the front Y-pipe and main cat during my L98 rebuild. I picked up a replacement 2 1/2 Y-pipe with no pre-cats and the o2 bung, then mated it to a replacement cat from Mid-America. All fit just like stock.
One word of caution, I can't be sure which item is responsible but I do have some "Droan" now that I can live without. Not sure if it is due to the 1/4" increased size of the pipe or the pre-cat removal, or combination. This is with Flowmaster mufflers.
I've got a rear Y-pipe with crossover tube on order now, and hope that makes the in car sound better.
Old Jun 16, 2009 | 01:15 PM
Redvette_22's Avatar
Redvette_22
PM sent
Old Jun 16, 2009 | 01:42 PM
BADDUCK's Avatar
BADDUCK
[QUOTE=Dolfan;1570467410]I just swapped the front Y-pipe and main cat during my L98 rebuild. I picked up a replacement 2 1/2 Y-pipe with no pre-cats and the o2 bung, then mated it to a replacement cat from Mid-America. All fit just like stock.
Most likely it is removing the pre cats. I have droan between 1400 and 1700 rpm and did not go to larger Y pipe. The Flowmasters are louder than my mufflers so you probably notice it more.
Old Jun 16, 2009 | 03:51 PM
Dolfan's Avatar
Dolfan
[QUOTE=BADDUCK;1570468798]
I hope the crossover tube helps a bit
Old Jun 16, 2009 | 05:44 PM
floridamale's Avatar
floridamale
I had this done to mine also because the pre cats were trash and rattling
Old Jun 16, 2009 | 05:59 PM
c4cruiser's Avatar
c4cruiser
You can always remove the front Y-pipe and "gut" the pre-cats. That way, you don't have to buy anything, don't have to deal with replacing the 02 sensor (which is usually rusted permanently in place), and you wind up with the same effect.
Old Jun 16, 2009 | 06:03 PM
floridamale
[QUOTE=Dolfan;1570470052]
I have the Walker rear crossover seems to cut down on interior noise
Old Jun 16, 2009 | 07:30 PM
TRINIDAVID's Avatar
TRINIDAVID
I have a 91 vette borla cat back exhaust. What should i do next replace the main cat and the pre cat ? Any suggestions?
Old Sep 2, 2009 | 03:30 AM
Phantom_Vette1's Avatar
Phantom_Vette1
Ok can someone please clarify! is the resonator actually a main cat? or just a noise muffler?
the reason i ask is i am thinking about getting a new y front pipe and getting rid of the pre-cats! but in my state we are required to have a cat by law! So if the resonator isn't a cat then it's a fineable offense! not to have one!
i am pretty sure a resonator isn't a cat!
Well it's not considered one on my other cars!
I wouldn't mind just getting two hiflo cats, but rather none if possible!
thanks
Old Sep 2, 2009 | 09:12 AM
c4cruiser's Avatar
c4cruiser
On the L98 cars, there are two pre-cats and a main cat. The front Y-pipe attaches to the main cat. There is no resonator. A single resonator appeared on the 92 and later LT1 powered cars. Those cars had individual larger single cats just below the exhaust manifolds. From there, each pipe connected to the center resonator.
Does your state have a visual inspection? If so, they may not like not seeing the missing two pre-cats. If you only have to pass an emissions (tailpipe) test, then the single cat at the end of the Y-pipe should work. There are some good high-flow cats that will bolt in and work.
Getting an exhaust shop to install true duals with cats or delete the cats altogether may be hard to do. There is a huge 5-figure fine from the feds if a shop gets caught removing working cats from a car that had them as original equipment.
Old Sep 2, 2009 | 04:59 PM
j-wireman's Avatar
j-wireman
I'm interested to see how this works out, especially drone-wise. This is almost the exact setup I am looking at, with the exception of a Random Technology main cat and, maybe, DynoMax High Performance mufflers. The mufflers (2-1/4 inlet), however, are not "carved in stone".
1. Did the front Y come with the O2 bung already welded on?
2. Is the rear Y 2-1/4" or 2-1/2" pipe? (I'm hoping it's the same diameter as the new cat's outlet.)
As you can see, I'm still "doing my homework".
Old Sep 4, 2009 | 11:51 AM
Phantom_Vette1
Thanks for the info, this has helped alot!
I think as long as there is one main cat(the centre one) it should be fine! i am pretty sure our inspections would look for a cat and have an emissions test aswell!
I know there is a huge fine for a shop and myself if found without a cat!
I was told by a fellow vette owner who did this exact modification! pre-cat elim, up to centre cat, then y pipe to mufflers! he said the shop told him it was legal to be rid of the pre-cats!
He gain more torque and that power feeling! and no real drone!
To No precat y pipe
