Plug wire help
Old Feb 9, 2002 | 05:22 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Plug wire help
I need to know the order that my plug wires hook up into my opti(from top to bottom on drivers and passenger side).
Old Feb 9, 2002 | 09:38 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Plug wire help (BAdAzZV8)
Looking at the Opti from front to rear,
or rear to front, same difference
Passenger side, top to btm, 4-6-8-2......
Drivers side, top to btm, 5-3-7-1........
Coudn't respond via "reply" a bit ago so I e-mailed a scan. :cheers:
Old Feb 9, 2002 | 10:05 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Plug wire help (lou sylvestri)
Now, could you tell me what the order is on the block(both sides)?
Old Feb 9, 2002 | 10:11 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
Are you talking the way the cylinders are numbered on the opti spark block?
The cylinders for the enigine are drivers side 1,3,5,7 passenger side 2,4,6,8
[Modified by 96GrandSport, 9:13 PM 2/9/2002]
[Modified by 96GrandSport, 9:15 PM 2/9/2002]
Old Feb 9, 2002 | 10:13 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Plug wire help (96GrandSport)
Yes, thank you.
To Plug wire help
