I have a 1989 Corvette L-98 and I want to remove the block plug that is between #1 and #3 plug. The plug in the block has a square opening and I can not find a tool that will fit it.
Does anyone know what tool I need to use to get this out.
When i knocked the freeze plug out of my buick to put in a block heater, i just used a hammer and a flathead screwdriver. Be careful though, coolant comes flyin out. I tried convincing my girlfriend to pound it out, but she wouldn't.
The hole is 5/16" if I recall correctly. I had a real tough time getting it out on my car. On the advice of someone on the forum I ended up going to Home Depot and buying a section of 5/16" square rod. I then cut a small piece to use as a "bit" and found a 12 point socket that fit snuggly on the end. I was able to get it out this way. It was still a major PITA as the rod isn't hardened and kept twisting. Make sure to spray it liberally with some type of penetrating oil.
Thanks that's a good idea. I know this plug is going to be tight so the 5/16 square rod sounds like the answer. Someone also said I should heat the plug until cherry red and let it cool, heat it again and put some motor oil on the plug to lube the threads.
Thanks for your help, I will let you know how I make out.
Well if it's 5/16 then any 3/8 extension is only 6/16. If you used a 5/16 open end wrench as measuring calipers couldn't you make your own tool with a grinder or file by taking off 1/16 on two adjacent sides?
You could just go down to Sears or an auto parts store and buy the socket that fits into the hole. That's what I did. Just WD40 will work fine.
Just keep in mind that these are pipe threads and the plug is tappered. So it looks like a "V" with the small end going into the block. You could also take a 3/8" extension and give it a small TAP with a hammer into the plug........should work. Use a breaker bar, you will need some leverage.
You have an '89, so I assume you stil have the factory aluminum heads. I'd have to say that's bad advice.
The proper tool you're looking for are a set of male pipe plug sockets.
I was thinking the same,this plug isnt IN the block but the head?
Thanks for all this information. The plug is the block it is cast Iron and not aluminum so I don't belive I have a problem with that. I went to sears and several auto stores. No one carries that socket. I have made up a tool using the back end of a pipe tap which does fits into the plug. I will try to remove it tonight using heat if I have too.
Keep us posted if you get it out.Most of those dont come out anymore.They seize into the heads and need alot of heat or sometimes drilling out to remove it.It really sucks.Good Luck!
Well it turn out great. I used the rear end of a tap and turned it with a stud remover attached to a 1/2 drive breaker bar. It was tight but it gave way and came right out. I connected the temp sensor and the car is running much cooler. Fan comes on at 200 and shut off at 185.
Guys thanks for all you help on this issue. This is really a great forum if you like working on corvette's.
