Datamaster Setup - Help
Old Feb 9, 2002 | 09:59 PM
92 ZR1's Avatar
92 ZR1
Default Datamaster Setup - Help
Trying to get the TTS Datamaster to work for the 1st time. Is there any special set up to the com port that I need to be doing. I am getting an error that the aldl is working but no communications from the pcm. Anyone else using this datamaster software?
Old Feb 10, 2002 | 01:50 AM
GlockLT4's Avatar
GlockLT4
Default Re: Datamaster Setup - Help (92 ZR1)
If it says your aldl module is working right, then you've got the com port selected properly. You need to be sure the cable from the module to the aldl is working. Also make sure the engine is on :)
[Modified by Glock'94, 12:19 AM 2/11/2002]
