89 L98 350,AFR190 heads,LPE 74219 cam,1.6 CC promagnum roller rockers. Will the standard length pushrods work? If not what length is correct or how do I determine the correct length?
Thanks,
Jim B. (VettePunk) :conehead
Re: Advice needed on correct pushrod length (vette punk)
I am in the same dilemna right now. I guess I'm going to order a pushrod length checker thingy from Summit. They are about $10. If you find out, let me know b/c I have almost the same setup as you. :cheers:
Vette Punk,
Went through the same exact thing. Check my post "The Project" You will need to get an adjustable pushrod from Comp Cams, I would suggest the "High Tech" one. It is very easy to use. Just read a lot and ask questions if not sure. It is very important to get this right! Mine came out to be 7.200" long. DO NOT ASSUME YOURS WILL BE THE SAME. Every engine setup is different! Let me know if you need more help. I will give some tip later.
