timing?
Old Feb 9, 2002 | 11:20 PM
vettedreams's Avatar
vettedreams
Default timing?
I'm having trouble with my'86 L-98, don't know if it 's the timing marks on the gears not lining up or not. The car runs at slow speeds well but if yougas it she will spark knock like heck. The timing is set properly and the engine heats up quickly to 200deg. under slow 35-45 mph. driving. The scanner also shows a elec. spark control code, any help sure would be studied, thanks
Old Feb 10, 2002 | 02:56 AM
weekendwrench's Avatar
weekendwrench
Default Re: timing? (vettedreams)
The ESC code could be from when you disconected the brown wire to set the timing. You did disconnect the wire before you set the timing? Clear the codes and see if it comes back.
Generally if the timing chain slips the car won't run at all. Post the numbers for the codes you get after you clear them.
Old Feb 10, 2002 | 03:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Check the connector to the knock sensor and ESC. You might pull the knock sensor to see if it's clogged, per someone's earlier post.
If you need an ESC do the upgrade sited in C4 Tech Tips or on my site. There is info on this upgrade with the GM part number there too.
Old Feb 10, 2002 | 02:20 PM
CFI-EFI's Avatar
CFI-EFI
As mentioned above:
A) Make sure the EST lead is disconnected when setting the base timing.
B) Make sure you RE-connect the EST lead after setting the timing.
C) Make sure you disconnect the battery power to the ECU to clear the codes.
If you have done the above, check the damper to be sure the outer ring hasn't slipped. If it has, the 6 degrees or what ever you're setting the timing to could be WAY off. Best way I know of, is to remove the #1 spark plug. Insert sonething (screwdriver?) and bring the piston up to TDC on the power stroke. See if the timing marks indicate TDC. If not, replace the damper. Good luck.
Old Feb 10, 2002 | 08:58 PM
vettedreams
Default Re: timing? (CFI-EFI)
Thanks for all the reply's. I decided to check the timing marks on the crank, after all it was an adjustable crank gear, lesson #1. Turns out that's what the problem was, there is a 0 and a dote about the same size, I lined the cam with the 0 instead of the dote. Any way ,I put the non- adjustable c.gear on, this should do it!
To timing?
