Code 43 ???
Old Feb 9, 2002 | 11:47 PM
blkc6z51's Avatar
blkc6z51
Default Code 43 ???
Hi All
While autoX today got a miss at high rpms, check for codes got a 43
so do I need to replace the knock sensor, or how can I test it.
Car is a 90 6 spd. Check eng light did come on. Thanks for any help.
Richard
[Modified by blk90, 9:48 PM 2/9/2002]
[Modified by blk90, 10:05 PM 2/9/2002]
Old Feb 10, 2002 | 01:03 AM
Ruby_Roadster's Avatar
Ruby_Roadster
Default Re: Code 43 ??? (blk90)
Double check the wiring and connectors first, sometimes if they come loose it'll give you a code. If that's ok, then you need to replace the knock sensors, I would suggest that you do both at the same time because if one's gone it won't be long before the other goes as well.
You can change them without draining the water, just make sure that engine is cold.
