mine were done a few months ago. Ended up using a propane torch to burn them out. Your gonna love the way your car rides after you install new front bushings.
[QUOTE=1SL0WC4;1570517121]just wondering what tools you guys used to get these out. I have Poly urethane bushings to install.[/QUO
Grease everything up really good or they'll squeak like crazy. Ask me how I know.
Is it alot of trouble to remove the control arms and replace the bushings? I noticed the bushings on mine have cracks in it. Though, I'm sure there are special tools needed I don't have.
The main thing with the upper A arm is to make sure you make up a brace to run between the arms when you press out/in the cross shaft. Without the brace you could easily break the arm.
Pain in the azz unless you have a press in your garage. I pressed out one side on a bench vise after much effort and gave up. Dropped them off at my brake shop. For $30 or so, they did upper and lower arms (bushing and lower ball joints too) in no time with their monster press. While waiting, I degreased the wheel wells.
