Camber Brace-*%$$##?????
Old Jun 21, 2009 | 01:43 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default Camber Brace-*%$$##?????
I know we have few racers and few that do Autocross,
Does the Camber Brace works?
I do have it in my 95 (for a long time), my 96 does not have it and I feel no difference between the Vettes.
Old Jun 21, 2009 | 07:32 PM
Aardwolf's Avatar
Aardwolf
I have my doubts that it helps (reduce track times) but I still haven't had time to make one and would like to try using it myself to find out.
Old Jun 21, 2009 | 11:33 PM
96GS#007's Avatar
96GS#007
I personally think that it does by maintaining a more consistent alignment, specifically camber, in the front.
Here's a simple test....With the car on the ground, measure the distance between the two front (or rear) upper a-arm bolts (ie measure across the car). Now jack the front end of the car up and measure again. You'll find that the measurement has changed. That is chassis flex. With the camber brace tying the two sides together, that flex is eliminated (and C4s need all the help they can get!).
Old Jun 22, 2009 | 10:32 AM
Aardwolf's Avatar
Aardwolf
There's no doubt it does flex but does it flex that much going around a corner? How much it moves by jacking it up and going around a corner could be very different.
Old Jun 22, 2009 | 11:30 AM
jwt1603's Avatar
jwt1603
I notice it more on low speed (30 to 60 mph) autcross events than on high speeds. I think the tighter turns on a low speed are where it really helps. I know I felt a difference because I had to do a repair at an event and had to pull it out and didn't put it back in. The co-driver noticed and mentioned it felt "looser' in front. I didn' tell her the brace was out of the car.
All that being said, I don't think it's worth the effort / cost for a street car.
Old Jun 22, 2009 | 12:24 PM
pianoguy's Avatar
pianoguy
I can't speak for its effectiveness in autocross, but for me it tighened up the front end a significant amount when I have the targa top off.
To Camber Brace-*%$$##?????
