Omni spark timing
Old Jun 21, 2009 | 09:05 PM
rpourcho's Avatar
rpourcho
Cruising
Default Omni spark timing
I have a friend that installed a new OMNI SPARK himself in his 1993 LT1. I went over, it is getting spark to the plugs but no fire. Should he have put the OMNI SPARK on wrong? Is there a procedure that he should of done to make sure the ROTOR was pointed in the correct direction? If so what is the procedure now to fix it? I think he has to take it apart again, but how do you get it timed to crank?
Old Jun 21, 2009 | 09:09 PM
farscape1a's Avatar
farscape1a
don't you mean OPTISPARK?
Old Jun 21, 2009 | 09:14 PM
rpourcho's Avatar
rpourcho
Cruising
Default Yep it is OPTI Spark
Yep sorry it is OPTI SPARK. Do you know whte answer?
Old Jun 21, 2009 | 09:52 PM
94z07fx3's Avatar
94z07fx3
The early opti-spark has a tiny key on the shaft (engine side) that is supposed to line up with a groove in the gear (distributor side). The thing about that tab A into slot B business on these older designs is that they don't prevent one from installing it wrong if he pushes a bit on it or allows the bolts to draw the distributor to the timing cover. So, yes, your buddy could have installed the optispark a bit out of time.
Old Jun 23, 2009 | 07:27 AM
rpourcho's Avatar
rpourcho
Cruising
Default What is the Procedure to re time the OPTI Spark?
Hi, Thanks for the reply's, where can I go to get the procedure to retime the OPTI Spark?
Old Jun 23, 2009 | 07:45 AM
pcolt94's Avatar
pcolt94
I don’t know of a formal procedure however the basic procedure is to watch and look to see what you are doing. Carefully installing the shaft into the engine and then carefully installing the opti on it the whole key.
It is probably best to turn the engine so when the shaft is installed in it, the keyway is at 12:00. Then set the keyway in the opti at 12:00 also and push on gently. Minimal force is required as it should fall on hitting the timing cover plate flush. The bolts only hold it I place and not pull it to the engine.
It would probably be wise to start the engine for a couple seconds before the water pump is installed. Put on the MAF temporally. If you don’t connect the water temp sensor it will run rich in about 10 seconds but will run. I like to connect the sensor though.
Old Jun 23, 2009 | 08:33 AM
neat's Avatar
neat
If the keyway wasn't aligned, and the bolts were used to pull the opti to the motor, it's possible that the opti is ruined. I would take the opti apart and check the rotor and wheel for damage. The encoder could also be damaged, but you likely won't be able to tell visually.
You'll need an inverted Torx bit to remove the cover from the opti, I think it's a number 10, but I don't remember for sure. Also, on re-assembly use a dab of locktite on the rotor screws. The screws have been known to work their way out over time.
Old Jun 23, 2009 | 09:22 AM
reoch999's Avatar
reoch999
It's an E4 external torx bit, but it's easier to make one than to find one in any tool store around here. Just find a torx screw head that fits (I wanna say it's a 25, but neat may be right with 10) and screw it into a stand off really tight using loctite or superglue, and use that as your opti screw bit. It was much cheaper than the $80 kit I would have had to buy just to get the only E4 bit I have seen in a store.
Old Jun 23, 2009 | 12:33 PM
warship's Avatar
warship
this may sound stupid but did you plug the plug wires in and rout them the right way? the fireing order and dis. plug order is not what most sbc guys would think. to make the wires come out on the propper side of the motor. just a thought.
Old Jun 23, 2009 | 02:13 PM
neat's Avatar
neat
You can find the inverted torx on a tool truck; Snap-on, MAC, Matco, etc... I found mine while I was at a GM dealership looking for parts. I saw the Snap-on truck drive by, headed to the shop. I ran out there and grabbed the guy before he left. He had the socket on the truck, it cost me $8.
Old Jun 23, 2009 | 02:51 PM
rpourcho's Avatar
rpourcho
Cruising
Hi to all, Thanks but you keep talking about a KEY WAY. This car's OPTI SPark shft had "gear's" at each end. You could put the shaft in any way you wanted to. So how do we get it back into sync with the motor?
Old Jun 23, 2009 | 03:09 PM
warship's Avatar
warship
not all of the "gear "is the same. its been a wile for me but eather one tooth is missing or there is one thicker tooth on the "splined" part of the shaft. and if you look at the hole in your cam, and int he hole of the opti, you should see the oposite. ther is no " key" like on a crankshaft. ( but our lt1's dont have that as well)
Old Jun 23, 2009 | 03:16 PM
94z07fx3's Avatar
94z07fx3
Look at this picture:
"You could put the shaft in any way you wanted to"
That is true but there is only one correct way to align the distributor to the shaft. The correct way fits on smoothly. All other ways need a bit of force to make it fit wrong.
The proceedure is to remove the opti, inspect it for damage as written above, re-install it correctly in time with the cam or replace it if the damage won't permit you to reuse this one.
Start the engine for a few seconds 10 or so with no water pump no intake bellows or MAF as a quick test to see if the engine runs before continuing with the reassembly.
Old Jun 23, 2009 | 03:28 PM
warship's Avatar
warship
thats just the picture needed
Old Jun 23, 2009 | 03:58 PM
bigwave71's Avatar
bigwave71
it would be hard to force the the distributor on the splined shaft wrong because of the large groove,it will only go on one way. if hes getting spark to the plugs but no run then he probably has the wires on the dist. in the wrong position. recheck the wires coming out of dist.
Old Jun 23, 2009 | 04:51 PM
rpourcho's Avatar
rpourcho
Cruising
1) Ok that is clear. So you are saying that there is a corresponding SLOT on the motor side?
Information: The Shaft on the OPTI SPARK did not have any SLOT. IT was continious GEARS. So I wouild have to incert shaft in the OPTI SPARK and mark the where the SLOT was. Then if the answer to #1 above is yes, then I would have to aline that with the motor slot.
Old Jun 23, 2009 | 05:18 PM
MikeC4's Avatar
MikeC4
Yes, the slot in the cam is also "keyed" . The keyed spline will fit only ONE way in the Opti and ONE way in the cam slot.
To Omni spark timing
Old Jun 23, 2009 | 05:22 PM
skybolt31's Avatar
skybolt31
i got one at autozone:
http://www.autozone.com/autozone/cat...layName=Socket
$2.99
Old Jun 23, 2009 | 05:27 PM
MikeC4's Avatar
MikeC4
Originally Posted by skybolt31
That inverse torx socket won't work for an Opti. You need a "deep wall" inverse torx socket for the recessed torx bolts.
You can get a set at Harbor Freight for pretty cheap :
http://www.harborfreight.com/cpi/cta...emnumber=95178
Old Jun 23, 2009 | 09:33 PM
pcolt94's Avatar
pcolt94
Flat spot filled in.
Need to look carfully.
Match it up with the opti (missing tooth) flat open area, and cam shaft.
