PulStar Spark Plugs
Old Jun 22, 2009 | 12:17 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default PulStar Spark Plugs
Is anyone using these plugs?
I got a brochure from an auto parts and I was wondering if they are what it says.
Here is the link for the LT1
Link for the L98
For the 95 LT5
Old Jun 22, 2009 | 01:01 AM
Demonic85's Avatar
Demonic85
snake oil. The only new design spark plugs that have been proven are the E3 diamondfire plugs. Even then the benefits dont really outweigh the cost. ($7 each)
Old Jun 22, 2009 | 01:36 AM
merlot566jka's Avatar
merlot566jka
buddy of mine tried them in his tbi truck, 5 hrs later he pulled them out and put delcos back in. they were causing shudder and misfire at idle.
Old Jun 22, 2009 | 07:44 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I've seen NGK Iridiums priced at $16 apiece, too, but I won't plunk that kinda' paper down on 'em.
Old Sep 4, 2009 | 08:05 PM
seevi's Avatar
seevi
The E3's aren't getting much praise on the forum.
Old Sep 4, 2009 | 10:11 PM
pianoguy's Avatar
pianoguy
Probably snake oil, but who knows. I've been searching around for reviews, found this one:
http://www.amcyclopedia.org/node/3001
Here's another, not particularly flattering:
http://www.srtforums.com/forums/5734850-post9.html
Old Sep 4, 2009 | 10:53 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Maybe I'll buy a set for my DD and see if it is worth it
Old Sep 4, 2009 | 10:57 PM
pianoguy's Avatar
pianoguy
Supposedly they have a money-back guarantee (within 30 days), so it might be worth a try.
Old Sep 5, 2009 | 12:50 AM
PLRX's Avatar
PLRX
2017 C4 of Year
It would not be worth on a C4. Once is good enough for spark #8. Imagine returning the set back to the auto parts, that would be removing it three times.
Old Sep 5, 2009 | 07:06 PM
jfb's Avatar
jfb
You can convince plenty of people with flowery advertising and wild claims that your spark plugs (or anything else) is much better than conventional plugs and charge a large multiple over conventional for them. Many people don't really understand how spark plugs work and can be convinced that E3's (or any other, "improved", plug) will work longer, give more HP, reduce emmisions, lower fuel consumption, ...blah blah blah!!!!!!! If their plugs are so good, then explain why every manufacturer still uses conventional spark plugs and have been since cars have been made. Why, because they work and, "new", plugs don't work any better!
A spark plug is merely a gap between two conductors where a spark can jump and ignite fuel/air inside a cylinder. Fairly recently long life spark plugs have been used by car makers and their life gets extended by using a semi precious metal for the electrodes which resists erosion much better than the steel electrodes used in more common spark plugs. I would advise you to use the plugs that your car manufacturer recommends and avoid plugs that make outlandish claims. Of course its your money and you can do whatever you want, but keep in mind that car makers aren't stupid and they continually test new products and if E3's were truly better, they would be in new cars.
Old Sep 5, 2009 | 08:31 PM
odecom5's Avatar
odecom5
not to hijack the thread but what kind of spark plugs would you guys recommend? Just getting ready to do a tune-up on my '85 L98.
Thanks!
Old Sep 5, 2009 | 10:12 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Stay away from the gimmick plugs. They're a waste of money. Good old copper core regular plugs work fine.
Old Sep 6, 2009 | 12:30 AM
Pwnage1337's Avatar
Pwnage1337
from pianoguy's link:
"So long story short they don't work and are piles of ****."
To PulStar Spark Plugs
