Do you recognise this bolt?
Old Jun 22, 2009 | 12:26 AM
Stingraynut's Avatar
Stingraynut
Default Do you recognise this bolt?
As I was entering my driveway I heard a metallic clink. I stopped and found this bolt in the gutter where my vette enters. 1988 Auto Coupe.
http://www.flickr.com/photos/37079655@N07/3648840749/
Please does anyone recognise it? It is a loose fit in a 10mm socket and a 3/8th socket goes halfway on, the head is maybe a little tapered, it's also badly rounded and I filed the burrs off to check the fit.
The only bolt I know that is this long holds the altenator bracket on and it's not that one.
Could it be front C beam bolt? or from the suspension? somewhere else? or not from my vette at all.
Old Jun 22, 2009 | 12:27 AM
Mark85Vett's Avatar
Mark85Vett
At first I thought it might be C beam, but it's much too short...
Old Jun 22, 2009 | 12:32 AM
jhammons01's Avatar
jhammons01
I'm thinking C-Beam....but it looks too short...lemme measure mine...
Yup, A C-beam Bolt is almost 7" long.
Old Jun 22, 2009 | 12:33 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Check your engine accessories, like the the alternator, smog pump, A/C comp, etc.... too small & short for a c-beam.
Old Jun 22, 2009 | 12:59 AM
Demonic85's Avatar
Demonic85
It kinda looks like a bolt from the rear suspension but they're longer than that. My guess is that its from an exhaust bracket.
Old Jun 22, 2009 | 01:34 AM
merlot566jka's Avatar
merlot566jka
its too clean to be an under-carriage bolt, I'm guessing an upper bracket on the engine.
Old Jun 22, 2009 | 02:11 AM
whalepirot's Avatar
whalepirot
Old Jun 22, 2009 | 05:04 AM
mechguy79's Avatar
mechguy79
Originally Posted by whalepirot
I'm with these guys. Sure hope you find it!
Old Jun 22, 2009 | 05:27 AM
Joe C's Avatar
Joe C
- check the alternator, especially behind the pully. even if loose, i don't know how it could have worked its way out...
Old Jun 22, 2009 | 05:44 AM
ddahlgren's Avatar
ddahlgren
If it just fell out it probaly was not on something turning at the time I would think that would have made a more spectacular exit..LOL Have you worked on any area of the car lately and could have forgoten to tighten something up? If I had to make a SWAG I am leaning towards starter. Are any bellhousing bolts that long? Just wild guesses..
Old Jun 22, 2009 | 06:00 AM
ddahlgren's Avatar
ddahlgren
Ok got clever and played detective and did a search for posts from you.. About a month ago lining up rear bumper and the body shop that did not get it lined up straight. What do they need to remove to get to the bumper bolts I bet it is on the list of things in the way.. Also to somewhat rounded head in that it fits a 10mm loose and 3/8 very tight would lead me to believe it started life as a 10mm and something that is on fairly tight.. Spare tire? Radio antenna? Gas tank? what has to come off to change a bumper I bet has something to do with the bolt.
Old Jun 22, 2009 | 06:07 AM
EastCoastHD's Avatar
EastCoastHD
Upper AIR pump bracket.
Old Jun 22, 2009 | 08:55 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
If it fell out of the starter it wasn't the right bolt anyway. Starter bolts have knurling around the shaft. I agree with everyone who guesses upper engine bracketry, especially the one EastCoastHD sent a pic of.
Old Jun 22, 2009 | 06:57 PM
Stingraynut
I found it!!!!! It was the forward top bolt holding the Nippondenso compressor.
EastCoastHD - that was my first thought, I checked immediately but the bolt was still there - also it's larger than 10mm, but the small bolt on that bracket, for the altenator, has exactly the same head, with the flange. I put my 10mm socket on it and it was identically as loose as on the bolt, so I knew then that the bolt WAS off my vette.
How lucky was I that it fell off at my driveway and not while driving.
ddahlgren - you qualify for the 'Sherlock Holmes' award, some clever sleuthing there. I was going to take the bolt to the people who fitted my bumper and ask them if it looked familiar!
Thanks EVERYONE for your help
Old Jun 23, 2009 | 12:38 AM
whalepirot's Avatar
whalepirot
I ran a K&N cone for a while but the power loss from high underhood temps was quite noticeable. The improvement when I fitted the '85+ hood to my '84, allowing the later C4 stock induction to pull the cool, pre-radiator air, was remarkable.
Originally Posted by EastCoastHD
Old Jun 23, 2009 | 01:06 AM
jhammons01's Avatar
jhammons01
wait, what does the compressor have to do with the bumper??
Old Jun 23, 2009 | 02:32 AM
JrRifleCoach
Its all relative;
To Do you recognise this bolt?
Old Jun 23, 2009 | 03:36 AM
tim32920's Avatar
tim32920
Close call!... i was looking for a missing bolt on my hd and my vette! LOL j/k glad ya found it.
Old Jun 23, 2009 | 05:46 AM
EastCoastHD
I know. After replacing the stock TB with a BBK 52 mm, the stock intake duct would not fit the larger TB. I tried heating with a heat gun and stretching, no luck.
Old Jun 23, 2009 | 08:18 AM
rodj's Avatar
rodj
Mount is no larger ,just that for some reason BBK have a ridge where as stock intake doesn't.
Little fit of filing makes it easier
