Battery
Old Jun 22, 2009 | 07:50 AM
JohnyH's Avatar
JohnyH
Default Battery
Is ther a Red Top battery that will fit in an 88 C4 properly?
Thanks John
Any other choices for a good battery that will fit properly?
Old Jun 24, 2009 | 04:57 PM
josephf31's Avatar
josephf31
Default I
Thanks John
don't like the Optimas
Have a new Interstate 75 fits perfect works great
Old Jun 24, 2009 | 06:31 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
ACDelco Professional grade (7 yr).
Will fit perfectly (remember to remove/reinstall the insulator foam wrap (or order it from Ecklers, etc if not on original).
Also, the ACDelco is designed to accept the higher-voltage charging rate of our C4's.
Old Jun 24, 2009 | 07:40 PM
jfb's Avatar
jfb
C4's don't charge batteries with any different voltage than other cars. Lead acid batteries have limits for charging voltage and C4 alternators stay within those limits.
Old Jun 24, 2009 | 07:44 PM
MK 82's Avatar
MK 82
Higher compared to what?
Old Jun 24, 2009 | 10:39 PM
JohnyH's Avatar
JohnyH
Thanks for the ccomments, went with the AC Delco, 7 year plan!
John
Old Jun 24, 2009 | 11:10 PM
theadmiral94
That's not true based on our Vettes and TransAm.
For example, on average, both vettes (and the TransAm) charge anywhere from 0.2 and 0.4 vDC above our Camry, given the same ambient temperatures and battery age.
Charging voltage differences as little as 0.2 vDC can make the difference between a battery gassing and loosing some 'acid' or not.
Noteworthy is that the GM cars originally came with 'maintenance free' batteries, whereas by example our Camry came with a traditional 'need maintenance' battery.
Also, Lead acid batteries are not all the same nor do they have the same ideal charging curves. For example, some true maintenance free battery has calcium added to help reduce gassing. This raises their gassing voltage and thereby their ideal charging curve.
Also, technically, AGMs, GEL, and spiral-gel batteries are 'lead acid' batteries, albeit the 'acid' may not be as liquid or the plates seperated differently. Nonetheless, very cleary documented by battery manufactures is the need for different charging voltages for these different 'technologies and the damage to them if charged higher than their ideal charging voltage (based on ambient temperatures). This difference can be as little as 0.2 vDC.
So, in my experience, the C4's (and C5's) Alternator's output voltage is higher than many other cars and is more designed for 'true maintenance free' batteries, like the ACDelco's. Hence my comments in my earlier post.
Old Jun 25, 2009 | 02:26 PM
dustmann's Avatar
dustmann
Default red top
I like and use the red tops. I had a battery leak out and eat the paint off of my fender. That will never happen with the red top. Douglas
Old Jun 28, 2009 | 09:08 AM
tixeon's Avatar
tixeon
I had a red top and it lasted two weeks before leaving me stranded with no warning. It wouldnt take a charge after that either. I went back to a conventional battery and havent had any troubles. Also,my C4 alternator puts out 14.4 V, where as my last Camaro put out 13.8 V. I dont know if this is significant.
Old Jun 28, 2009 | 11:21 PM
jfb's Avatar
jfb
If you look up the upper and lower voltage limits allowed for GM alternators you will find that the range FAR exceeds the recommended charging voltages for the different style car batteries. Talking about 0.2 volts difference between cars is laughable in the light of the production voltage tolerances.
To Battery
