Rear spring code/rate conversions?
Old Jun 28, 2009 | 09:42 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Default Rear spring code/rate conversions?
I put a C4 suspension under my '69, and am looking to stiffen up the rear. I have a suspension info chart that was published a few years back, but it only relates the spring rates and the year/option codes. I need some sort of conversion chart that lists the three letter broadcast code and the rate, so I can use this info when shopping for springs at swap meets or web auctions.
Can anybody help me out here?
Thanks,
Mike
Old Jun 28, 2009 | 09:48 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default vette
here you go.
http://www.idavette.net/susp_chart.htm
Corvette Mike
Old Jun 28, 2009 | 09:58 PM
69427's Avatar
69427
Thanks for the reply, but that's the chart I already have. I need one that has the three letter spring broadcast codes, not the vehicle RPO codes. The broadcast codes are molded/stamped into the spring.
Old Jun 28, 2009 | 10:21 PM
WVZR-1's Avatar
WVZR-1
The "stoutest" rear spring is the '84 FE7 (BMH) so I've heard!
Here are others:
'84 w/o FE7: BMF
'85 - '88 Coupe FE7: NYU
'89 - '92 FE7: NYU w/o FX3
'89 - '90 FE7 w/FX3: NYR
'92 - ZR-1: RHY
'87 - '91 Coupe FE1: NYR
'85 - '92 Verts FE1: RCA
You should be able to use these and use the charts subbing FE7 for Z51
Old Jun 28, 2009 | 10:55 PM
Mojave's Avatar
Mojave
Spring rates
front 84-87
bmb 102
hmz 63.5
hkx 39.9
hmp 39.9
hm2? 57.2
hmn 54.4
front 88-96
fha 93.1
fhb 115.5
fhc 93.1
aa 96.2
fsk 90.1
fsm 75.4
fss 90.1
fsr 73.2
ha 60
ja 60
rear 84-96
bmf 72
bmh 87.5
nyu 57.2
nyr 39.9
rca 39.9
rhy 39.9
rhz 39.9
rr 26
Old Jun 28, 2009 | 11:27 PM
69427's Avatar
69427
Originally Posted by Mojave
Spring rates
front 84-87
bmb 102
hmz 63.5
hkx 39.9
hmp 39.9
hm2? 57.2
hmn 54.4
front 88-96
fha 93.1
fhb 115.5
fhc 93.1
aa 96.2
fsk 90.1
fsm 75.4
fss 90.1
fsr 73.2
ha 60
ja 60
rear 84-96
bmf 72
bmh 87.5
nyu 57.2
nyr 39.9
rca 39.9
rhy 39.9
rhz 39.9
rr 26
Impressive! That's the info I was looking for. I do appreciate your help.
Old Jun 29, 2009 | 01:00 AM
Mojave's Avatar
Mojave
I just got coil overs, so I'm going to be pulling off an FHB front spring and BMH rear spring pretty soon if you're looking for some springs.
To Rear spring code/rate conversions?
