Clutch Pedal removal
Old Jun 23, 2009 | 11:11 PM
pipe's Avatar
pipe
Default Clutch Pedal removal
I was under the dam dash getting a sore neck trying to figure out how to remove the clutch and brake pedal assy. Do I need to remove the carpeted bolster to see more area where the bolts are? I want to put in the pedal assy. from an automatic car. There's so much stuff under there it's hard to see where the fasteners are. Help before I get a torch and get under there and burn the dam thing up. THANKS Pipe
Old Jun 24, 2009 | 01:50 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
You can't see sh*t unless you remove the hush panel.
Old Jun 24, 2009 | 07:05 PM
pipe's Avatar
pipe
Thanks Randy thats a start. I won't have to remove the brake booster assy. to get to any of the bolts from the outside will I ? THANKS FOR ANY HELP Pipe
To Clutch Pedal removal
