Chamber Size???
Old Jun 26, 2009 | 11:23 PM
pearlvett's Avatar
pearlvett
Default Chamber Size???
Ok so im lookin to get some new heads on my 85 soon and i was just tryin to figure out if 58cc chambers would cause too much compresion for the bottom end and if 76cc chambers wouldnt have enough compresion. I would appreciate some help with this little hitch in my plans. Thanks ahead of time!
Old Jun 27, 2009 | 01:16 AM
Mark85Vett's Avatar
Mark85Vett
I had that exact prob...put a set of 113's that were decked .010, and the starter wouldn't even crank it over! It was a $30 Autozone special, but the compression would be too high to run on pump gas anyway. I ended up going with AFR 0919's...65cc chambers, 180cc runners.
Old Jun 27, 2009 | 07:24 AM
MR NICE's Avatar
MR NICE
I'm running 64cc heads on my 85,starts no problem,i'm sure 58 cc heads will work but you may need to run higher octane gas.
Old Jun 27, 2009 | 10:00 AM
vader86's Avatar
vader86
Stock heads are 76cc on 85-86E, so that would keep you at the same CR. Going to 58cc would probably bump it to around 11:1 with a stock gasket, so you will be using premium.
85s bottom end wouldnt have a problem with it. With a colder plug you should be ok.
I would recommend going to a bit thicker gasket though, just to bring it into a safer zone.
Old Jun 27, 2009 | 10:51 AM
pearlvett's Avatar
pearlvett
What is the compresion ratio on the stock heads? I am thinking it might be safer to go with the 76cc heads and running a cam rather than the 58cc with a cam...Whats yalls opinion?
Old Jun 27, 2009 | 11:35 PM
pearlvett's Avatar
pearlvett
ttt...need help!
Old Jun 28, 2009 | 08:35 AM
MR NICE's Avatar
MR NICE
The stock heads are junk 76 cc,go with some 64 cc heads.just about any aftermarket head is better cast iron or alum.
Old Jun 28, 2009 | 10:25 AM
Aardwolf's Avatar
Aardwolf
If I were you I would use 113's and use the $1200 saved to have fun with the car.
Old Jun 28, 2009 | 11:42 AM
ddahlgren's Avatar
ddahlgren
Now there is a plan.. keep on cruising.... sounds like $1200 would buy a dinner for two times ten or twelve at least so for the object of your affection + fuel for the hot hot and fun riding with the top off on a warm summer nights for a couple of months.. seems like a no brainer..LOL but that is from a mid fifties old fart not a drag racer young guy..LOL.. after 350 hp and 400 ft lbs just how much you going to put through street times on a public road without attracting the attention of every cop for 20 square miles???
Old Jun 28, 2009 | 05:05 PM
CFI-EFI's Avatar
CFI-EFI
Your stock heads had 76 ccs and your engine had a 9.0:1 compression ratio. You can easily figure a new compression ratio with different sized combustion chambers when you know the engine size and the two chamber sizes.
I don't know what caused the problem reported by Mark85Vett, but it wasn't caused by the combustion chamber size.
RACE ON!!!
Old Jun 28, 2009 | 06:12 PM
Mojave's Avatar
Mojave
It would take a lot of compression to stop the starter. My LT4 is 12.5:1 and the stock starter has no issues.
Old Jun 28, 2009 | 08:09 PM
project C4's Avatar
project C4
Default zz4
the zz4 crate motor is a flat top motor with 58cc chambers.
gm lists the compression at 10:1
Old Jun 28, 2009 | 08:16 PM
Demonic85's Avatar
Demonic85
I put 70cc heads on my '85 which bumped it to 9.5:1 and can still run on 87.
To Chamber Size???
