e brake strength
The parking brake do not have their own shoes/pads, they use the rear brakes, so doubtful you need to replace pads (as otherwise the brakes would be a problem too).
However, most often the problem is one of the wheel cables which rust internally and prevent the cable from moving within its sheath to pull the caliper/piston actuating arm which pushes the brake pad against the rotor.
Suggest removing the plastic cover over the parking brake mechanism and inspect the parking brake mechanism for rust (water leaks often get to it). Then refer to the FSM and release the self-adjuster's tension.
If the tension doesn't release, either the mechanism is rusted/stuck or the cables are rusted and stuck.
If you are able to release some of the tension, suggest removing the rear wheels, and get underneath the car and release the cables and then see which cable(s) is stuck and needs to be replaced.
The only emergency you will have if you have to use it in a emergency stop. I just don’t think the pads are big enough for the rears as we all know the rears don’t brake very much.
One answer I got from another Forum member is that it is not an emergence brake, it is a parking brake.
Want another shock, pick the rear of the car up, run the engine and put the car in drive. Then step on the brake and see if you can stop the rear wheels.
First of all, it is a parking brake, not an E brake. To apply it properly you must first apply the brakes then pull up on the handle.
Pull one of the rear wheels and have a buddy apply the brake while you watch the caliper. The caliper pads should remain applied when the pedal is released.
