Can i drive home???
Old Feb 11, 2002 | 08:25 AM
Daniel DK's Avatar
Daniel DK
Default Can i drive home???
ok i'm at work and went to pick up lunc. When i turned the key i noteced the "low coolant"- light came on. So i cheked the level and there was allmost no water in the tank. So i put allmost a gallon of clean water started her up and began so serius eyeballing :eek: and realized that i have a pinhole in my radiator:smash: . I've got allmost 6 miles home ... will it be ok running clean water?? :confused: :cheers:
Old Feb 11, 2002 | 08:42 AM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Can i drive home??? (Daniel DK)
You'll be fine.. just make sure it's full. Pure water disapates heat better then water/antifreeze.
Old Feb 11, 2002 | 09:15 AM
vader86's Avatar
vader86
Default Re: Can i drive home??? (Springer's 95)
since im guessing that its colder in Denmark than it is here, you can drive it only when the temperature is warm outside, you cant drive it w/o antifreeze in the cold weather, its too dangerous in the mornings. Get that radiator fixed as soon as possible.
Old Feb 11, 2002 | 09:30 AM
Daniel DK's Avatar
Daniel DK
Default Re: Can i drive home??? (vader86)
ok - i was worried about lubrication of the waterpump..... we have 45 F so i won't worry about cracking the block... i'll put some glycol in when i get home... she is gonna stay i the garage for a while - until payday. I feel realy bad for not beeing able to fix her right away, especialy because i just bought a daily ricer......
Old Feb 11, 2002 | 11:11 AM
Nathan Plemons's Avatar
Nathan Plemons
daily ricer......
:jester
To Can i drive home???
