hot cam work well with ported SR intake?
Old Jun 29, 2009 | 06:11 PM
pologreen1's Avatar
pologreen1
Default hot cam work well with ported SR intake?
how ould an lt4 hotcam work with a ported out super ram?
compared to te 219 or better, since I don't need emissons anymore
Old Jun 29, 2009 | 06:28 PM
STL94LT1's Avatar
STL94LT1
Running the superram I would stick with the 219 over the Hot Cam
Old Jun 29, 2009 | 07:27 PM
Zoomin1's Avatar
Zoomin1
219 is the best bet. Hot cam gives you 11 degrees more duration on the exhaust that you don't need. 219 gives a nice but rough idle. Very streetable but says "I have a cam, Don't FFFF with me" Hot cam might bring 5 more HP to the table but very rough idle and tempermental around town. Just my opinion though.........
Old Jun 29, 2009 | 07:41 PM
pologreen1's Avatar
pologreen1
I figured to stick with the plan of the 219, or just swap for a bigger motor instead of this bother
Old Jun 30, 2009 | 08:07 AM
bjankuski's Avatar
bjankuski
The hot cam will work fine and may be a better choice depending on what heads you have. If the exhaust side is restrictive the hot cam will work better then the 219. If you have a good flowing exaust system the 219 may be better.
To hot cam work well with ported SR intake?
