Adjustable FPR, can't get below 46psi. WHY???
Old Jun 29, 2009 | 06:15 PM
jackdk's Avatar
jackdk
Default Adjustable FPR, can't get below 46psi. WHY???
Since I changed injectors in my 88 coupe to Bosch III injectors from Jon at FIC, (car runs fantastic BTW) I also added an adjustable fuel preasure regulator. I can't get my fuel preasure adjusted below 46psi. I want to get it to the 43.5 that Jon suggest for my car. The car is running slightly rich, but goes like heck when you mash it. WHY? can't I get it lower. The adjusting screw is backed all the way out at 46 psi, and in danger of coming out of the housing, and will not go any lower.
Are there any members that have had a similar problem, or know what would cause this?
Thanks in advance. Jack
Old Jun 29, 2009 | 07:42 PM
pologreen1's Avatar
pologreen1
Old Jun 29, 2009 | 08:24 PM
Ed Ramberger's Avatar
Ed Ramberger
Once you have the screw backed all the way out and the AFPR is on it's lowest setting, it is what it is. High pressure/volume fuel pumps will contribute to this as wll. I have seen this several times.
If you do have a high pres/vol pump in the car, you may find that a stock regulator gets overrun as well.
Also, the pressure setting changes with the vacuum line hooked to the regulator (it will be lower at idle with the line installed and higher with it removed)
Old Jun 29, 2009 | 10:44 PM
ch@0s's Avatar
ch@0s
you could have a restriction in the fuel return line
Old Jun 29, 2009 | 11:01 PM
jackdk's Avatar
jackdk
How, or where do I start to check for a restriction in the return line? I noticed the other night, I stopped for gas. When I went to take off the gas cap, there was a huge amount of preasure built up in the tank. I just cracked the cap, and it took about 20 seconds to release the preasure. Is this normal, or part of my problem. I know the adjustment screw is touching any thing in the adfp regulator, and its at 46 psi.
Old Jun 30, 2009 | 07:56 AM
pcolt94's Avatar
pcolt94
Pressure in the tank is normal. Every time I unscrew my cap it does the same as yours.
When did you first notice the problem, was it there before the new FPR.
Did you measured the fuel pressure before all the changes you did?
Possibly the FPR is defective or range of adjustment is wrong for your set up. You might want to re-install the original FPR and see what the pressure is. This might assist you in finding the problem and you have the same pump as before.
Old Jun 30, 2009 | 08:14 AM
85C4sX2's Avatar
85C4sX2
I had this problem with one fpr that I bought. I do not remember the brand but it came with just the adjustable cap and a disc that you placed inside to allow the adjusting screw to depress the spring. This unit required that you use the original diaphragm and spring. With the screw backed out completely, the disc still had pressure on the spring and would not allow the pressure to drop.
I solved this by buying a Holley FPR that came complete with a new diaphragm and spring. With this unit I was able to fully adjust my fuel pressure.
Old Jun 30, 2009 | 08:57 AM
jackdk's Avatar
jackdk
I never seemed to have pressure in the tank, but I noticed that GM had a recall on 88-89-90 for one of the emision hoses to one of the canisters. GM fixed it the last time I had it in the shop. It was all dry rotted. Since they replaced that, I get pressure built up in the tank. So I was wondering if it was because of some sort of blockage, causing me not being able to get an adjustment...
Old Jun 30, 2009 | 08:58 AM
ddahlgren's Avatar
ddahlgren
Most of those are made assuming you want to raise the pressure so little concern is made for having stock pressure. the spring is either too stiff or the adjuster parts ave smimed the spring to a new higher pressure. You might try putting a gasket shim between the cover and body of the regulator to take some preload out of the spring.
Old Jun 30, 2009 | 09:03 AM
jackdk's Avatar
jackdk
I installed the adfp regulator the same time I installed the injectors last summer. I had the same problem with the adjustment then. It ran fine regardless, but a little rich, so I left well enough alone. But I figured I did something wrong. Went to reset it yesterday, after I noticed the pressure build up in the tank, and I got the same results with the adjustment. I can feel that the disc or adjustment screw isn't even touching anything. Its that lose. I did buy the unit off ebay, and it only came with the cap, and disc. I did also put in a new diaphragm.
Old Jun 30, 2009 | 09:11 AM
tmichaud's Avatar
tmichaud
Not sure which brand or type you have...but the one that I got (aeromotive unit) actually came with two different springs - one for lower pressures, another for higher...
Old Jun 30, 2009 | 09:27 AM
jackdk's Avatar
jackdk
Holy Crap !!! That don't sound good! Mine didn't come with springs. The only spring on mine is on the diaphram. All that was in the box was the cover, disc, and adjustment screw. Where are these springs suppose to go?
Old Jun 30, 2009 | 11:11 AM
tmichaud's Avatar
tmichaud
heh - it would depend on the one that you got....
I have this regulator - and it actually shows in the picture the other spring. One is good up to 20psi, the other from 20 to 60psi...
http://www.summitracing.com/parts/AE...1/?image=large
I suspect this is not the regulator you have based on you not being able to go below 46.....
Old Jun 30, 2009 | 11:45 AM
jackdk's Avatar
jackdk
The one I have is from TPI Parts, www.tpiparts.net part #FUL-200. It does not include, or call for any springs. I sent them an email to see why I can get below 46 psi. Still waiting for a reply. I will check out the one you have.
Thanks,
Old Jun 30, 2009 | 12:02 PM
jeffp1167's Avatar
jeffp1167
tpi used different regulators for different pressures not sure what years they were different though. but if memory serves me right 85-87 was different then 88-up I think it's due to earlier tpi's having bosche injectors and the later multechs. I could be wrong though but maybe thats why you have the issue.
Old Jun 30, 2009 | 08:34 PM
redrose's Avatar
redrose
btdt...cutting half a coil off the spring worked on one...bulldozed the spring on another by fully compressing it in the bench vise overnite (wrap a shop cloth around vice jaws/spring if you try this at home and don't enjoy spring hunting)
Old Jun 30, 2009 | 08:41 PM
ch@0s's Avatar
ch@0s
I also have a TPI parts regulator. I noticed that with the spacer they give you, there is tension on the spring when you bolt it up. I tossed the spacer and bought a longer bolt. I don't remenber what size the bolt was but I think it was 1/2" longer it that helps.
I took the return line loose and blew throught it. Now I can get my pressure down to 44 I couldn't get it lower than 50 before. There could also be rust in your return line.
To Adjustable FPR, can't get below 46psi. WHY???
Old Jun 30, 2009 | 10:40 PM
jackdk's Avatar
jackdk
I'll blast some air through the return line. There could be rust or something in there. This car sat a good bit before I bought it. As far as the longer bolt? Don't think that will work for me, because its backed all the way out. As soon as I turn it in, and it touches the diaphragm, it increases the fp. Its at 46 now. I want it lower, but not sure if 3 psi is enough to make it run rich.
Thanks...
Old Jun 30, 2009 | 11:27 PM
ch@0s's Avatar
ch@0s
Thanks...
Maybe? that's a question for Jon... Jon u out there?
Is your engine stock? what size injectors?
You Could also have a vacuum leak causing you to run rich, not uncommon with TPI.
Old Jul 1, 2009 | 01:49 AM
Demonic85's Avatar
Demonic85
'85 is the only year thats different because it used 24 lb injectors so it had to run at 33-35 psi. Later years have 22 lb injectors and operate at about 40-43 psi.
