Steel Flywheel Experience
Old Jun 30, 2009 | 08:51 AM
Nihilum's Avatar
Nihilum
Cruising
Default Steel Flywheel Experience
Hello everyone,
I'm thinking of converting my 89 corvette zf 6 speed from a dual mass flywheel to a single mass solid steel flywheel from Carolina Clutch. However, I'm worried about the new sounds that may arise with this less expensive, and less complex, flywheel. Would someone who has converted their own car please give me some clue as to the difference in sound between the two flywheels? Is it simply a matter of more gear whine, or is there a rocks in a can rattling kind of sound present? Please share your experiences. You would be a big help to me.
Thanks!
Joshua
Old Jun 30, 2009 | 09:58 AM
neat's Avatar
neat
I have a single mass in my 91. It's louder than the DMF by about 10% at cruise, and the rocks sound is much more prevalent.
If you're looking for quiet, it's not the way to go.
I did run an aluminum flywheel with a McLeod twin disk clutch for awhile, and it was quiet as could be at idle. It was louder at cruise, but for some reason that combo didn't make any noise at all when idling.
Old Jun 30, 2009 | 11:07 AM
LD85's Avatar
LD85
I have never had a DMF, but I believe that everyone believes that the SMF is louder than the DMF
If you want the least noise, the DMF appears to be the solution, if you can find, recent forum purchasers indicate a cost @ of $900-$1000 for a DMF
Most loudness
1. Aluminum Fidanza FW
2. Single Mass FW
3. Dual Mass Fw
Old Jun 30, 2009 | 11:13 AM
ultraviolet70's Avatar
ultraviolet70
Had '91 with SM aluminum. With the stock cam the and a chip tuned to idle at 900+rpm the engine was smooth enough that at idle it made no more noise than the DM. This was just my experience, it seems that everyone has varying results.
Old Jun 30, 2009 | 11:52 AM
Nihilum's Avatar
Nihilum
Cruising
I have another question about the single mass steel flywheel. Did you guys who installed one have to send it out to have it balanced with the motor?
Thanks!
Old Jun 30, 2009 | 12:07 PM
slickfx3's Avatar
slickfx3
Thanks!
spec brand comes with a weight for the application, mine was zero'd so i took it off.
if the entire enviorment is noisey it won't matter much, but if it is stock, the rattleing at idle and 1100 -1600 rpm crusie state has a loud roar, at least in my case, in every gear
forget the single mass you'll lose some inertia and make it a little harder to take off.
get dmf unless you want every last bit of HP to get trophies....
Old Jun 30, 2009 | 12:14 PM
Nihilum's Avatar
Nihilum
Cruising
Slick,
Horsepower is not entering into the equation at all. I'm simply trying to find an economical, reliable way to fix the flywheel. Chevrolet is the only place that I can find the flywheel, but they want about $1100 for it. I spoke with Carolina Clutch, the supplier of a single mass steel flywheel kit, and they claim that the increase in noise is noticeable, yet minimal.
Joshua
Old Jun 30, 2009 | 12:20 PM
slickfx3's Avatar
slickfx3
Slick,
Joshua
my feeling is if yor are after quiet it will diff not be, and will annoy the living doo doo out of you.
choke up the money auto zone sells them for around 700...
you will appriciate the quiet, plain and simple, my corsa and engine is so loud it doesn't matter, it is just a noise machine otoh, yours may not be..
keep your sanity, i don't have any experience with a sprung hub disc which supposedly helps with the
"racket", i could not find one that fit, after 2 tries with summit i gave up and threw the old stock one back in....
Old Jun 30, 2009 | 12:50 PM
Nihilum's Avatar
Nihilum
Cruising
Slick,
Auto Zone gave me a price of $650 for the DM flywheel, which sounded awesome. The only problem is that they've been discontinued and are hence not available right now. I don't mind paying $650, but $1100, which seems to be the best I can find, is a tad too much for me personally.
Joshua
Old Jun 30, 2009 | 12:52 PM
slickfx3's Avatar
slickfx3
Slick,
Joshua
well whats the prob with yours? can't you keep using it?
Old Jun 30, 2009 | 12:53 PM
neat's Avatar
neat
I would be surprised if you could actually get one from the dealer. I'm sure you could pay, and they could order it, but actually getting it in your hands would surprise me.
Old Jun 30, 2009 | 12:59 PM
Nihilum's Avatar
Nihilum
Cruising
Slick,
Sorry to confuse you. I had another thread, entitled "Dual Mass Flywheel Problem," where I discussed the problems that I was having with the flywheel.
Joshua
Old Jun 30, 2009 | 01:10 PM
slickfx3's Avatar
slickfx3
Slick,
Joshua
change your atittude, the 35k miles is low in my estimation, plausably ( there are differing opinions about rubber dampers even existing in these things, there may be 2 types the original and the updated dmf, yours may not have that update and may not have rubber coushions, Ive seen confusion on this with no difinitive answers even from GM chevy mechanics) not even having a problem.
save your time and money and drive it until you can't and the car won't go, that is what i would do, but that is just me, those dmf are very very strong and 38 lbs.
this is my regurgitation of information i learned from here, so it could just be barf.
Old Jun 30, 2009 | 01:24 PM
Nihilum's Avatar
Nihilum
Cruising
Thanks very much for your advice, Slick. Unfortunately though, it is not a quiet sound and does demand immediate attention. I wish I didn't have to be so truncated right now in my speech, but I'm at work right now and trying to write this in the middle of dealing with customers.
Joshua
To Steel Flywheel Experience
