Steering Problem
Old Jun 30, 2009 | 09:28 AM
saber7469's Avatar
saber7469
Default Steering Problem
Normally I have a vague idea of what the problem is but this one, not a clue.
On the way to work this morning, every time I let off the throttle the car would steer to the right. Not really hard but enopugh to notice and wonder about. Any thoughts??
'93, LT-1, auto trans, cut air lid, PCM chip, cat back Magna Flow system, and MSD ignition.
Thanks for your time.
Old Jun 30, 2009 | 11:14 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Sounds like something got knocked out of alignment. Have a 4 wheel alignment done.
Old Jun 30, 2009 | 04:27 PM
saber7469's Avatar
saber7469
If it was an alignment issue wouldn't it put to the right all the time? This only does if I come off the throttle quickly.???
Old Jun 30, 2009 | 04:39 PM
0Paul Ruggeri
Former Vendor
There may be something loose or worn that moves under a load. A good alignment tech will find this.
Old Jun 30, 2009 | 04:49 PM
saber7469's Avatar
saber7469
I'll have them chaeck it out, thanks. Pete
Old Jun 30, 2009 | 07:03 PM
Kinkajou's Avatar
Kinkajou
Check the right rear caliper. Maybe it gets a little stuck in the pin . It should slide with ease.
So when you are on the throttle the brake can break a little bit loose, when you let off if friction is high you will steer. A little bit like a Tank.
Also check for low or high tire pressure.
Good luck
Old Jun 30, 2009 | 08:40 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Is the tire pressure even side to side front and rear?
Old Jun 30, 2009 | 08:53 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Any chance you have hit a curb or pothole with a rear tire?
You may have knocked the rear end out of alignment.
Old Jul 1, 2009 | 09:52 AM
saber7469's Avatar
saber7469
Thanks for the inputs, tire pressure is same all around, and I will pull the right rear tire and take a good look at the brake caliper. After that I think I will get a professional to take a look.
Thanks for the ideas,
Pete
Old Jul 1, 2009 | 03:36 PM
Chapindad's Avatar
Chapindad
Check the wear on your rear tires. I had this problem and after a few days the tire ate itself up. It eventually happend to both rear tires at different times. I put new tires on and everything is perfect. I think it was because the tires where old and the rubber had stiffen.
Old Jul 1, 2009 | 03:42 PM
pologreen1's Avatar
pologreen1
tire pressure, sticky brake, alignment, (possibly) a wheel or weight problem
Old Jul 1, 2009 | 03:50 PM
CAJUN C4's Avatar
CAJUN C4
Could be a Bad Rear Wheel Bearing. Your tire is possibly moving in to out and or visa versa I had that happen on my 84' which had over
150K Miles on it.
Old Jul 1, 2009 | 03:57 PM
M. Schumacher's Avatar
M. Schumacher
You're not the first owner to make that observation and, in fact, my 96 does the same thing. It is very slight and you notice it more, or less, on different surfaces.
I think it might be bushings. I've changed the rear stabilizer bushings which seemed to help. Next up are the batwing bushings with a rearend swap. Then we'll take it from there. I don't want to just change them all at once because I want to determine the effect of each change.
To Steering Problem
