Horn relay??
Old Jul 1, 2009 | 04:52 PM
pearlvett's Avatar
pearlvett
Default Horn relay??
Where is the horn relay in an 85 corvette? My horns work if you put the power direct and the switch works...but the horns dont honk when you push the button. I think the relay for the horn is bad but cant find it! Thanks ahead of time for your help!
Old Jul 1, 2009 | 06:06 PM
ant-knee470's Avatar
ant-knee470
Check the fuses first, but the horn relay is right behind info panel, Where the check engine light is & security light.. Behind that panel..
Old Jul 1, 2009 | 06:21 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It could also be the contacts in the steering wheel ring.
Old Jul 1, 2009 | 06:29 PM
pearlvett's Avatar
pearlvett
No fuse in the fuse box is labeled horn. I would like to find it to be that easy but no clue which fuse goes to horn.
Old Jul 1, 2009 | 06:30 PM
pearlvett's Avatar
pearlvett
Anyway to test that without removing the wheel?
Old Jul 1, 2009 | 06:36 PM
ant-knee470
I look in the book, Give me a few minutes
Old Jul 1, 2009 | 06:46 PM
ant-knee470
Well there could be a couple fuses, cause of the security system, so the horn is on a few circuits... But You can pull one at a time & look at the fuses & if the fuse is broken it is bad...
Old Jul 1, 2009 | 07:09 PM
pearlvett's Avatar
pearlvett
Thanks but the only fuse blown is the cour. lights is that one the fuses that the horn is tied to? However I seem to remember the horn working after I had the light issue. still have a light issue!
Old Jul 1, 2009 | 07:29 PM
ant-knee470
I think it does work on that circuit but not sure I will check on my car in five minutes, If you have a fuse throw it in & see, If that does not do it.. I would change the relay, If that does not do it, Most likely it is in the column,
Old Jul 1, 2009 | 11:49 PM
vette_lover2004's Avatar
vette_lover2004
Cruising
I had this same problem with my 87...I fixed this by pulling the two metal contacts behind the button...It appeared someone punched the horn button once or twice...basically forcing the contact bars rearward and sideways...bent them back...and my horn works perfectly
To Horn relay??
