Sloppy tilt -- old problem, new question
Old Jul 4, 2009 | 12:41 AM
josephf31's Avatar
josephf31
Default Sloppy tilt -- old problem, new question
I have read about and tried the quick fixes (JB Weld, etc.) for the loose tilt column on my '91 coupe. It's better but still not great; I know one way to fix it is replace the column (the tilt portion alone is no longer available, I think).
I was wondering...I am pretty sure I saw a message somewhere, on some forum, about someone who fixed the problem pretty well by buying "oversize" pivot pins and getting them into the (worn out/aluminum?) housing...
Does *anyone* know if there ever was or is now such a thing as "oversize" pins for the tilt wheel mechanism?
If not commercially available, I was thinking I might be able to get someone to machine a pair of pins in some oversize (not sure exactly, guessing somewhere between 5 and 40 thousandths?) that would fix the problem...
Thoughts/suggestions/etc? Thanks!!
Old Jul 4, 2009 | 09:49 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default check this
Mark Maibeck has the steering pin. Read this thread for more detail.
http://forums.corvetteforum.com/c4-g...wheel-fix.html
Old Jul 4, 2009 | 02:02 PM
josephf31's Avatar
josephf31
Default That
seems to be what I was looking for but there is no contact information to get in touch with Mark Maibeck for the pins, anyone know it? Thanks!!
Old Jul 4, 2009 | 03:01 PM
2012 coupe's Avatar
2012 coupe
Default Tilt wheel problem
GM part # to fix this problem: 26002678
Old Jul 4, 2009 | 04:43 PM
josephf31's Avatar
josephf31
Default What
part is that, exactly? The housing? I thought it was discontinued...? thx!
To Sloppy tilt -- old problem, new question
