Loctite for runners/plenum?
Old Feb 12, 2002 | 07:03 AM
Gregory VanLare's Avatar
Gregory VanLare
Default Loctite for runners/plenum?
I'm putting my runners and plenum back on, do I need any loctite on the bolts or just tighten them down to 19#s?
Old Feb 12, 2002 | 09:47 AM
Jim85IROC's Avatar
Jim85IROC
Default Re: Loctite for runners/plenum? (Gregory VanLare)
I've never had mine loosen and I don't use loctite.
Old Feb 12, 2002 | 10:34 AM
Oh My's Avatar
Oh My
Default Re: Loctite for runners/plenum? (Jim85IROC)
i heavily suggest not using loctite, just tighten them down.
Old Feb 12, 2002 | 11:05 AM
Vic'89's Avatar
Vic'89
Just tighten them down and use anti-seize compound on them.
Vic
Old Feb 12, 2002 | 05:32 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Loctite for runners/plenum? (Vic'89)
I agree with Vic...use anti seize on the bolt threads, just a little dab is good.
Be sure the threads and thread holes are clean before using.
Old Feb 12, 2002 | 05:58 PM
cohocarl's Avatar
cohocarl
I wouldn't use any loctite on them. Next time you needed to get them out, the aluminum threads that used to be in the plenum may come out with the bolts.:eek:
I've had my plenum & runners off and on a few times had have never used any loctite on the bolts.
Old Feb 12, 2002 | 09:48 PM
Gregory VanLare
Thanks, I'll not use anything!! The bolts were coated with crud when I took them out and I wasn't sure what it was! I've got the new injectors in and the plenum is ported and ready to go back in. I had to order new o rings for the cold start injector. That is the last step before I can finish putting it back together. I can hardly wait to see if it goes back together (and runs again)!! I've certainly had a lot of help from all the threads I've read and feedback I've gotten to my simple questions! I'll let you know what the outcome is! Hope to get some work time in on it this weekend.
Old Feb 12, 2002 | 11:01 PM
M2001's Avatar
M2001
When I yanked off my intake manifold, I also found crud on the bolts. I cleaned off all the bolt threads with a stainless steel bristle brush. When I installed the bolts, the bolt threaded into the base very smoothly with no bind whats so ever. The bolts are torqued more accurately without all the crud on them. Take the time to clean off all the bolts.
Old Feb 13, 2002 | 12:56 AM
88_vette's Avatar
88_vette
Default Re: Loctite for runners/plenum? (M2001)
As vic'89 said use anti seize(spelling?) You are suppose to use some kind of a lub for alum items think this. Just a little as said.
To Loctite for runners/plenum?
