crankshaft sensor
Old Jul 5, 2009 | 01:09 PM
jsiratt's Avatar
jsiratt
Cruising
Default crankshaft sensor
I have a 1993 corvette that will not start. It cranks but won't start. I changed the fuel pump because it was not getting the correct pressure. I also cleaned the rails for the injectors. When I checked the injectors wiring they do not pulse but are hot constant. I believe it may be the crankshaft sensor. Where is it located any help would be great.
Old Jul 5, 2009 | 01:11 PM
grinditout's Avatar
grinditout
inside the optispark.
STL94LT1's Avatar
STL94LT1
Your 93 doesn't have a separate crankshaft sensor.
Old Jul 5, 2009 | 01:13 PM
joecarter85's Avatar
joecarter85
There is no crankshaft sensor on a '93 LT1. The Optispark determines crank position via the low resolution pulses delivered by the Optical wheel.
just FYI, the '96 was the only year C4 with a CPS.
jsiratt's Avatar
jsiratt
Cruising
any idea what the problem could be
Old Jul 5, 2009 | 01:16 PM
STL94LT1's Avatar
STL94LT1
Any codes?
Old Jul 5, 2009 | 01:17 PM
joecarter85
Did you use an inductive pickup noid light to check for injector pulses ??
You can't just put a DVM on the connector as you are not looking for a static voltage.
jsiratt's Avatar
jsiratt
Cruising
how would i fix this?
Old Jul 5, 2009 | 01:19 PM
jsiratt's Avatar
jsiratt
Cruising
there is constant voltage on both wires going in but no pulse when crnking
Old Jul 5, 2009 | 01:20 PM
jsiratt's Avatar
jsiratt
Cruising
where is wheel located?
Old Jul 5, 2009 | 01:21 PM
jsiratt's Avatar
jsiratt
Cruising
no codes
jsiratt's Avatar
jsiratt
Cruising
where is the optispark?
Old Jul 5, 2009 | 01:22 PM
joecarter85
You can't use a digital voltmeter to get any meaningful results on the pulsing of your injectors. The DVM cannot react in such a fashion. One wire will have constant voltage and the other is switched back and forth from "open" to ground.
Old Jul 5, 2009 | 01:23 PM
STL94LT1's Avatar
STL94LT1
Under the water pump.
Old Jul 5, 2009 | 01:24 PM
joecarter85
Old Jul 5, 2009 | 01:25 PM
jsiratt's Avatar
jsiratt
Cruising
I understand that I used a light and when tested the light stays on constantly with no pulse.
Old Jul 5, 2009 | 01:28 PM
jsiratt's Avatar
jsiratt
Cruising
is all part of one unit? with the distributor?
To crankshaft sensor
Old Jul 5, 2009 | 01:31 PM
STL94LT1's Avatar
STL94LT1
The optispark is the distributor.
joecarter85
Forgetting about the injectors for a moment, have you checked for spark ??
<AIR> <FUEL><SPARK>
Let's figure out which one you are missing.....
Old Jul 5, 2009 | 01:32 PM
jsiratt's Avatar
jsiratt
Cruising
Thank you guys for all your help
this site is great.
