problem with ECON switch on 89
Old Feb 12, 2002 | 11:50 AM
cadawg's Avatar
cadawg
Default problem with ECON switch on 89
All of the other air conditioning/heating buttons work except when I press ECON nothing happens(the light does not even come on)? Is this a bad switch? a fuse someplace? something else? How do I track this down? Any help would be much appreciated!
[Modified by cadawg, 7:25 AM 2/13/2002]
Old Feb 13, 2002 | 01:37 PM
cadawg's Avatar
cadawg
Default Re: problem with ECON switch on 89 (cadawg)
Anyone got any suggestions? Thanks in advance
Old Feb 13, 2002 | 01:55 PM
-=Jeff=-'s Avatar
-=Jeff=-
sounds like the control is bad... if it were a fuse the whole thing would not work
Old Feb 13, 2002 | 02:04 PM
cadawg's Avatar
cadawg
Default Re: problem with ECON switch on 89 (-=Jeff=-)
Thanks for your help, now I have to find somewhere to get it fixed.... Is this a major job (expensive)? Is it something a complete novice could attempt without messing up other things?
Old Feb 13, 2002 | 02:19 PM
-=Jeff=-'s Avatar
-=Jeff=-
you could buy the unit and install yourself..
but you may want to have it checked.. it sounds like the control unit is bad but might be something eles..
The Last Detail has them for decent prices..
http://www.tld-corvette.com
Also for a novice it should be fairly easy to replace
Old Feb 13, 2002 | 02:52 PM
cadawg's Avatar
cadawg
Where is the control unit located, and how do I get to it??
Old Feb 13, 2002 | 03:01 PM
pablocruise's Avatar
pablocruise
maybe this will help: http://www.idavette.net/tech/c4diag.htm
hope so. goodluck! :cheers:
Old Feb 13, 2002 | 09:09 PM
cadawg's Avatar
cadawg
Default Re: problem with ECON switch on 89 (89 Paul in cal)
Thanks! looks like good stuff. Where is the control unit and how do I change it?
Thanks again
To problem with ECON switch on 89
