changing spark plugs.
Old Jul 6, 2009 | 09:03 PM
MP6's Avatar
MP6
Default changing spark plugs.
How do i change the plugs on a 92 lt1? whats the easiest way to get to them and change them? those things are deep!
Old Jul 6, 2009 | 10:18 PM
aminnich's Avatar
aminnich
Hire a double jointed midget on steroids. There is no easy way.
Old Jul 6, 2009 | 11:00 PM
MP6's Avatar
MP6
so how do you get to them?
Old Jul 6, 2009 | 11:56 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Good tools and patience. A good indexable head ratchet, an assortment of extensions, a universal joint and a GOOD spark plug socket as well as different length ratchets. There is no EASY way to change them but if you have QUALITY tools it's not that bad. Wobble extesions are nice too. Some of the plugs aren't bad at all, the center of the wheel well comes out which gives a different angle at some.
Old Jul 7, 2009 | 12:15 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
driver side: For #1 & #3, It helps if you remove the inner fenders central section and for 32 & #4 disconnect the air hose
passenger side: for #6 & #8 use a 1/4 rachet, remove the wires' bracket.
To remove and install the straight plug boot is another PIA. #8 is easy if you use the 1/4 rachet.
Are you changing the plug wires?
Old Jul 7, 2009 | 12:21 AM
LT4 F45's Avatar
LT4 F45
on LT1 passenger side is not bad at all but driver side you will need good tools and a big load of patience and if not needed forget about the spark plug wires but everything can be done...
Old Jul 7, 2009 | 06:59 AM
pcolt94's Avatar
pcolt94
Un-bolting and moving the ASR out of the way helps a lot on the drivers side. I did not have much problems on that side after that. But the rear two on the passenger side is where I really worked hard to get them in and out. A good assortment of tools were definitely the key to getting it done as JD said.
Old Jul 7, 2009 | 07:52 AM
runner140*'s Avatar
runner140*
Do it in two segments...the left side and the right side. It will take about an hour a side. Don't rush, have patients, you'll get done.
Old Jul 7, 2009 | 10:31 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Here's a write-up I did, page down a few and you'll see info on how to remove/install:
http://forums.corvetteforum.com/c4-g...r55ix-gap.html
Old Jul 7, 2009 | 12:40 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The No. 8 plug on the passenger side is a legendary ****.
Old Jul 7, 2009 | 11:03 PM
MP6's Avatar
MP6
THANKS! should be fun!
Old Jul 7, 2009 | 11:21 PM
94z07fx3's Avatar
94z07fx3
For number eight, there are many solutions. Try this one. Sit on the passenger side wheel with your back to the engine and use just your right hand to start the threads. I use a short piece of fuel hose over the ceramic part of the plug to start them. The hose will spin on the plug before they can be cross-threaded.
Old Jul 8, 2009 | 12:16 PM
onedef92's Avatar
onedef92
That's the technique I used, too.
To changing spark plugs.
