First Vette
Old Jul 6, 2009 | 09:28 PM
SS Performance's Avatar
SS Performance
Cruising
Default First Vette
I just got my first Vette (87)
I am wondering what are the differences in the suspension for the various years.
Wilwood offers front brakes for the 88-96. What is different with the 84-87 front spindle/suspension and the 88-96?
I have heard the rear suspension is narrower in the 84-87 than the 88-96.
Any help would be greatly appreciated.
Old Jul 6, 2009 | 09:52 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
There is a FAQ at the top of the tech page for general info by year.
Old Jul 6, 2009 | 11:43 PM
Omnivec's Avatar
Omnivec
Cruising
Well I looked though the faq and I couldn't find almost any info on year differences in brakes.
Old Jul 7, 2009 | 01:49 AM
Demonic85's Avatar
Demonic85
The rear suspension didnt change much. The front suspension was redesigned in '88 for zero scrub and therefore parts will not interchange between early (84-87) and later suspensions. The offset is also different '84-'87 uses +38mm, '88+ uses +56mm, this is important if you're considering new wheels.
Old Jul 7, 2009 | 01:46 PM
SS Performance
Cruising
I appreciate the feed back.
I did check the FAQ section and found the info on the wheel offset.
I am trying to determine a little more about the differences in the spindles. If I can get enough info I want to make brackets to mount Wilwood brakes.
Again thanks for the info.
Old Jul 7, 2009 | 02:46 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Here is a C4 suspension specification chart. However, it does not include information on the brakes.
FYI,
P.
File Type: doc
To First Vette
