Gordon Killibrew says use only Simple Green cleaner on the early and mid-year silver painted C4 Valve Covers because it will not react with the metal or the paint. On an '89 that I bought new, I did that and since the discoloration that plagues these valve covers never got a chance to get started, it worked out well. Long story short, I've got a 90 now that has the standard brown color which comes with not cleaning them after each trip. I know it's impossible to get rid of a majority of the discoloration--and refinishing is the only real solution--but I'm wondering if any of you have found a cleaner that will at least make a dent in the ugliness?
If you soak the valve covers(or anything painted) in Simple Green concentrate it will actually take the paint off if you leave them immersed for a day or so. We use it in our parts cleaner to loosen dirt and paint; I'm a big fan of Simple Green!
I guess if you wash it off after application, it doesn't harm the finish but if you leave it on, that's a different story. Killibrew was adamant about using only Simple Green but he did say rinse the engine thoroughly after you use it.
I just wiped mine down with thinner and sprayed them. There were a few small casting bubbles I tried to smooth with file. Very easy! Here's a picture:
That's the V/C paint from Corvette Central. I ordered something else from them and tried the paint. I've repainted them twice now and still have paint left in the can. Mine get pretty banged up removing them so often. WTH is with that brown color? At first I thought some kid owned the car or gave their dad a fathers day present by using deck stain on them.
I didn't attempt to remove the brown at all, just cleaned it up so the new paint would stick. It's held up real well except where I've bumped it during R&R's.
I just hit it with some sandpaper to clean up the castings a bit. I'm pretty sure I used a primer when I did mine...
So clean...
Could you use the valve cover paint to paint the plenum/runners/base if you wanted to give it a new look? Its all the same color right?
I'm doing mine right now. I've got the driver side off and the paint stripped. I'll prime it with Zinc Chromate, then use Rustoleum High Temp Silver for the color.
My emblem as the paint coming off. There is only red on there. I'm gonna finish taking the rest of the paint off, and reglue it as is. I say it would look aftermarket since it has a mirror finish under the paint.
I had a problem getting the driver side off as the booster vacuum line runs through a plate that is bolted on the back of the head. I have since been told to just bend the bracket to the firewall to give enough clearance to remove/install the cover.
I've also been told to go with the Felpro rubber valve cover gaskets. Which I bought a set from Autozone.
I did clean the engine up first since with the leaking valve covers, there was alot of grime. I just hate that there are alot of little screws that like to rust up. I even used compressed air to dry the engine off afterwards.
