[Washer Pump]: Replace?
Old Feb 12, 2002 | 12:46 PM
scorp508's Avatar
scorp508
Default [Washer Pump]: Replace?
Mine groans and moans louder than a cheap porno, and the waster fluid doesn't seem all that forcefull. Does anyone elses make noise when running? Should I just replace it?
Old Feb 12, 2002 | 03:11 PM
scorp508's Avatar
scorp508
Glad to see I have the only defective one. :)
Old Feb 12, 2002 | 03:16 PM
C4 4Me's Avatar
C4 4Me
Cruise-In II Veteran
Default Re: (scorp508)
Take a look and see if where it sucks fluid in is clogged or corroded. Worked on an old Ford of mine, don't know if these are the same.
Old Feb 12, 2002 | 05:14 PM
91Vette's Avatar
91Vette
Default Re: [Washer Pump]: Replace? (scorp508)
Mine was making a weird groaning noise when I replaced it. It also was leaking some antifreeze at the bottom weep holes.
If you are in doubt, I'd replace it. The job is a bit tedious, but it's not too difficult.
To [Washer Pump]: Replace?
