Dashboard Display
Old Jul 7, 2009 | 05:20 PM
Blastoff's Avatar
Blastoff
Default Dashboard Display
Hello all,
I recently picked up an older vette {86}, with a blown head gasket {and warped heads} I replaced the heads, and got it running pretty well. I knew when i bought it, it was going to be a project car, so there were no real supprises with regard to its condition. still needs an exhaust system, and some work on its interior. I will post some pics as soon as i figure out how. The reason for this post though, is a question i have regarding the dashboard display. It is very dim, visible during the day, but at night...nothing. Has anyone else encountered this? if so, any advice would be appreciated.
Old Jul 7, 2009 | 05:30 PM
scorp508's Avatar
scorp508
There are 4 bulbs in the dash that sometimes blow out. They're not too hard to replace if you have a semi-steady hand. Does the whole thing look dim or is one quadrant lit up while the others are dark? If they're all out there may be a grounding issue.
Old Jul 7, 2009 | 05:55 PM
WW7's Avatar
WW7
Here are the instructions for replacing the bulbs if that is your problem, its either the bulbs or your light sensor in the cluster has gone bad..WW
http://www.batee.com/corvette/dcrg/lightbulb.shtml
If you find you have to remove the cluster, here are directions for that...
http://www.batee.com/corvette/dcrg/repair.htm
Old Jul 7, 2009 | 06:05 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
You say dim during the day and nothing at night. If "at night" means with the headlights on, then you may only have to turn the headlight **** to "undim" the dash lights. If that's not it, Battee.com has a chapter on the digital dash fix, and if you google, you will find a Corvette Mag article online that details it as well.
Old Jul 7, 2009 | 06:09 PM
Blastoff's Avatar
Blastoff
Hello Scorp508,
Thanks for you're reply. I don't think there are bulbs, i think it's LCD. As i said before, during the day it looks OK, a little dim, but OK. But at night, you cannot see the display at all. It's like none of it gets bright enough to see. The indicators WITH bulbs, like the brake light, coolant level, etc. are visible. But the speedometer, tach, gas gauge, and all of the other liquid crystal display gauges need help.
Old Jul 7, 2009 | 06:12 PM
Blastoff's Avatar
Blastoff
Thank all you guys for you're replys. I'll let you know what i come up with.
Old Jul 7, 2009 | 06:20 PM
scorp508's Avatar
scorp508
Originally Posted by Blastoff
Hello Scorp508,
Oh there are bulbs back there, you'll have to trust me/us on this.
The display is LCD, but it is kind of backwards from what you'd expect an LCD display to do. In the C4 display the LCDs are 'black' when no current is going through them, preventing you from seeing the light those 4 bulbs give off shining through the colored film behind the actual LCD panes. The car then 'turns on' LCDs as necessary to make them clear so you can see the colored parts of the display.
Old Jul 7, 2009 | 06:25 PM
WW7's Avatar
WW7
Read the links that I put there for you, don't assume!!...WW
Old Jul 7, 2009 | 06:40 PM
jhammons01's Avatar
jhammons01
Hello Scorp508,
Thanks for you're reply. I don't think there are bulbs, .
I'll be more direct
Blastoff, you aren't listening.
http://forums.corvetteforum.com/c4-t...r-problem.html
This question comes up three times per week on this forum. Trust....trust....
I'm not sure you went to Batee.com like WW posted. If you did you'd see what we are talking about.....4 bulbs
LCD=Liquid crystal display...the crystals are in a liquid....when you excite them with a voltage they move aside and allow a backlight to shine through a colored lens. So when you think the pretty green part has gone dark.....the green part stayed the same...some black liquid just covered it up.
Old Jul 7, 2009 | 11:01 PM
Jim McCombe's Avatar
Jim McCombe
Originally Posted by jhammons01
I'll be more direct
Listen to JHammons, he knows what he is talking about.
A few weeks ago I had a similiar problem and he put me in the right direction with the light cluster problem that I had.
If you have to replace the 4 little lights, go with the Xenon. They burn much cooler and will not burn your circuit board.
Old Jul 7, 2009 | 11:08 PM
scorp508's Avatar
scorp508
The next time I change mine I am going with HID.
Old Jul 8, 2009 | 11:14 AM
Blastoff's Avatar
Blastoff
Hello jhammons01,
I am listening, and i did check out Batee.com, it was very helpful. I have not had a chance to pull it apart yet. When i went back out to the car yesterday, i encountered a more pressing issue, my main fan is not working. When i first bought the car about a month ago, i replaced the radiator, thermostat, and fan motor. I am not getting any voltage at the fan, so i'm guessing it might be a problem with the relay. I let it run until the coolant temp reached 215 degrees. The secondary fan kicked in, but the main fan did not. I have a copy of chiltons corvette repair manuel, but theres not much info regarding the fan, or it's control circuitry. If anyone can direct me to the location of the relay, it would be very helpful. BTW, it's a relief to hear that my dash problems might be nothing more than burnt out bulbs. I'll let you know how it turns out. Thanks.
Old Jul 8, 2009 | 11:27 AM
scorp508's Avatar
scorp508
The fan relays should be on rear portion of the the driver side wheel well.
Old Jul 8, 2009 | 11:38 AM
Blastoff's Avatar
Blastoff
Thanks Scorp. Ill let you know how it turns out. I just posted two photos, their in the "non" corvette catagory. I'm new at this. If anyone is interested, i took a bunch of photos while changing the heads. Thanks again.
Old Jul 8, 2009 | 03:32 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
The fan has dual programming.
1. with air conditioning off, the main fan comes on at 225, and goes off at 215.
2. with air conditioning on, the fan comes on at 220, and goes off at 210
I have an 86, so I know the concern.
BTW,
on the dash bulbs, you have to pull the dash overlay from off the display, and under it, there are 4 shiny metal covers.
you pull the metal covers, and there's a bulb in each hole
Old Jul 8, 2009 | 04:47 PM
floridamale's Avatar
floridamale
The LCD is a backlit display, Listen up people here will not steer you wrong beside if it still dosen't work what are you out some light bulbs. Good luck
Old Jul 8, 2009 | 05:16 PM
MK 82's Avatar
MK 82
????? Are you saying the fan does not come immediately on a cold engine with AC on?
To Dashboard Display
Old Jul 8, 2009 | 05:42 PM
floridamale
I was wondering about that myself on my 87 with A/C on at idle the fan comes on once pressure is built up in system. I don’t recall the actual numbers but it comes on very fast. Also over a certain speed I believe the fan goes off but not sure I thought it's something like 35mph. It's all controled through the ECM and the sensor input.
Old Jul 8, 2009 | 06:52 PM
jhammons01's Avatar
jhammons01
^^maybe, but if the fan is not supposed to come on until ~230°.....that would explain a "no voltage" situation exist at 215°
This is one of those....."Fix it until it breaks" situations.
Old Jul 8, 2009 | 07:41 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Hello jhammons01,
Use the Chiltons to level a table and get a FSM, both books with the red cover.
