Removing VC emblem
Old Jul 8, 2009 | 10:57 AM
whitess's Avatar
whitess
Default Removing VC emblem
I need to take the emblem off of my Magnesium valve covers so I can bead blast them. I looked at it and there doesn't seem to be a simple way to take it off. I don't mind if it breaks I'll replace it if needed.
Thanks,
Larry.
Old Jul 8, 2009 | 11:19 AM
Dolfan's Avatar
Dolfan
It's originally put on with some type of adhesive, just work around the emblem with a putty knife and you should be able to get it to loosen up. Since your refinishing you can get a few scratches on the covers.
I reattached mine with "The Right Stuff" that I used on the intake gasket.
Old Jul 8, 2009 | 11:33 AM
Dolfan's Avatar
Dolfan
It is possible to repaint the emblem, this is how mine came out.
http://forums.corvetteforum.com/c4-t...no-picaso.html
Old Jul 8, 2009 | 11:57 AM
jimg's'93's Avatar
jimg's'93
I used a feeler gauge to work around the edges until the adhesive released from the cover. Got them both off perfectly with no bends.
Old Jul 8, 2009 | 12:04 PM
whitess's Avatar
whitess
Thanks all. These will be a great help. If I have to repaint it I've got a great example as well.
Larry.
Old Jul 8, 2009 | 03:53 PM
Hideki's Avatar
Hideki
When I was cleaning my valve covers mine just fell off like stated earlier, a small putty knife should do the trick. If your blasting your covers anyways I wouldn't be concerned with leaving some of the old sticky tape behind.
Old Jul 8, 2009 | 04:40 PM
floridamale's Avatar
floridamale
Use a strong fishing line work it back & forth underneath like a saw do it when its a little hot comes right off with out damage
Old Jul 8, 2009 | 05:40 PM
whitess's Avatar
whitess
Y'all are a great help, buy yourselves a beer.
To Removing VC emblem
