ac system
Old Jul 9, 2009 | 11:23 PM
chris schaefer's Avatar
chris schaefer
1st Gear
Default ac system
is the cooling fan suppose to run as soon as the ac compressor is turned on and if so what would cause it not too.
Old Jul 9, 2009 | 11:30 PM
Dads90's Avatar
Dads90
Hey Chris , welcome to the forum. Might fill out your profile so we know what year we are talking about.
Old Jul 10, 2009 | 10:43 AM
SunCr's Avatar
SunCr
Not always - ECM driven, it depends on the temperature/pressure of the gas after the Condensor. For '85 to '89, a pressure sensitive switch signals the ECM when it reaches a threshold of about 230 psi. After that, a thermistor in the high pressure line sends a voltage that's proportional to pressure. Pressure is dependent on outside air temp or the temp of the air cooling the Condensor. Most designs drive the fan(s) to maintain an average pressure of 200 psi. Realistically, a fully charged system will make these numbers within seconds if it's 70 or better. Below that, they will cycle on/off and below 50, nothing may come on until there's some heat from the engine compartment. Troubleshoot with a manifold gage set (for pressure), scanner ('90 and above), and through '89, disconnecting the switch on the high pressure line should turn on the fan (meaning the ECM is working correctly and it's something else).
To ac system
