Melonized distributor gear substitute?
Old Jul 10, 2009 | 10:06 AM
Qiken's Avatar
Qiken
Default Melonized distributor gear substitute?
Does anyone do a compatable Melonized gear ,or is GM the only option?
Old Jul 10, 2009 | 10:09 AM
94z07fx3's Avatar
94z07fx3
Have you considered emailing SummitRacing with what you want? If it's out there in the aftermarket I bet they carry it.
Old Jul 10, 2009 | 09:53 PM
C409's Avatar
C409
Melonized ??? Don't know that one , but my friend's girlfriend is a
MELANCHOLY .... chest of melons ... face of collie ...
Old Jul 11, 2009 | 01:05 AM
Qiken's Avatar
Qiken
Not quite.... the melonized distributor gear for the roller cam
Old Jul 11, 2009 | 01:42 AM
rpoL98's Avatar
rpoL98
I think the only other similar option is the Comp Cams composite distributor gear.
Old Jul 11, 2009 | 10:18 AM
856SPEED's Avatar
856SPEED
you can look into the bronze distributor gears sold by most auto parts retailers....they have to order them sometimes....I went w/the GM melonized gear by recommendations however...
Old Jul 11, 2009 | 07:58 PM
C409's Avatar
C409
Seiously now.... I'm installing a retro hyd Comp Cams roller cam in my early block so I e-mailed Comp tech for their recommendation on distributor gear , Their suggestion was to use Chevy '90 - up gear. My research turned up part # 10456413 ...
Old Jul 12, 2009 | 07:51 AM
JAKE's Avatar
JAKE
Comp's gear is over the top, price-wise. I bought my melonized gear from a local Chevy dealer. Surprisingly, it was much cheaper than Comp's gear.
Jake
West Point ROCKS!
Old Jul 12, 2009 | 08:16 AM
catlettlt1's Avatar
catlettlt1
The only problem is they don't fit directly without machining a collar,
the shaft is like .475 and the smallest gear avail. from comp cams is
.491 its no problem is you can get a collar made to make up the difference.
To Melonized distributor gear substitute?
