Plenum, runners are off........
Old Feb 12, 2002 | 11:15 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Plenum, runners are off........
Replacing leaking lower intake gaskets.
Removed my plenum and runners.......have not yet removed the base yet. Need to be cleaned......is Hydrofloric acid ok to soak them in? Is there somthing else I should soak them in?? I am going to do this before I port the plenum......have not decided on siamesing the runners?
Any ideas appreciated on cleaners and siamesing the runners! :cheers:
Old Feb 12, 2002 | 11:36 PM
dtorc4's Avatar
dtorc4
Default Re: Plenum, runners are off........ (KNCRSR5R)
Here are a couple of links for siamesing the runners and intake:
http://www.eecis.udel.edu/~davis/z28...16siamesebase/
http://www.eecis.udel.edu/~davis/z28...sebaseporting/
Good luck!! :cheers:
Old Feb 13, 2002 | 02:24 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Try to get all of the water that may be in the intake base out before you remove it. Also, if your intake isn't very clean, try to vacuum up any dust etc you can before pulling the base so as to minimise the amount of crud you have to pull out of the valley (you will have some stuff fall in when you pull the base) - also pulling the base will take some effort before it wants to budge... Also, just in case - make sure you mark the distributors position before you remove it (sorry if I'm stating the obvious).
Acid should be okay, I've used degreaser and since then have found you could probably use mag wheel cleaner as a milder alternative although acid will probably give the best results.
Lastly, I'd clean stuff AFTER I ported it, you will have to clean any metal filings out afterwards so save yourself having to clean it twice.
As for siamesing, do your homework before you make the first cut. I remember this was a hot topic for a while but people have quietened down about it lately and I'm not sure if there is a reason for that. Initially I read it may cause excessively lean mixtures (if I recall correctly) but never looked into it further because I wasn't too keen to try it myself.
[Modified by Red 90 L98 Coupe, 12:25 AM 2/13/2002]
Old Feb 13, 2002 | 03:33 AM
pablocruise's Avatar
pablocruise
Default Re: Plenum, runners are off........ (Red 90 L98 Coupe)
Been there done that. I recommend doing BOTH before and after cuz the shavings "stick" stubbornly to the grime. They "cling" less to clean Al.
You've noticed it too huh? I ruined a stock base by too much porting causing reversion in the 5/7 intake tract. Also, yes, the EGR gasses did dilute the mixture to too lean. (suggestion to Erik: don't take out much wall in the 5/7 tract)
I ended up buying the Edelbrock intake seen in the link in Dtorc4's post above. It stops breathing at around 4800RPM
[Modified by 89 Paul in cal, 11:46 PM 2/12/2002]
Old Feb 13, 2002 | 04:04 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I don't recommend HCL for cleaning your parts. I agree, try a degreaser of take them to be hot tanked.
I'm in Phoenix, AZ for a short and just picked up a set of LT runners at AS&M in Chandler, AZ. After inspecting the product I pulled out my plastic and charged the $395 for the set. They should provide a 45% increase in flow potential based on runner diameter and they look like stock, from the outside.
I'm still trying to find a used base to try that Siamesed base trick on.
Old Feb 13, 2002 | 07:05 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: Plenum, runners are off........ (65Z01)
Thanks for the info! I dont think I am going to siamese these things! I am already craaving a drive and just tore it down last night! LOL :yesnod:
I
To Plenum, runners are off........
