my left headlight is too low and needs to be adjusted. can i adjust them myself.
Park the car on a level surface facing a wall (car ~ 10' away)or garage door then turn the headlights on and see which light beam is projecting lower on the wall/door. Adjust the 2 screws for the light until you get what your after.
.....well I may have miss interpreted his question....my bad
Not your bad engle, his bad,this is why its important to be specific..If engle1147s answer is not the right one try this one...
If it is the headlight door itself that your talking about being to low there are 2 rubber stops, one on top, one on bottom that you can adjust in or out to make the headlight door even with the hood ..WW
