OK,.....Where is it??????????
Old Feb 13, 2002 | 01:08 PM
vette87's Avatar
vette87
Default OK,.....Where is it??????????
I am doing the water pump on my 87 and I have to remove the compressor mounting bracket to get the wp out. I have removed all the bolts I can find and its still mounted solid as a rock. Ok this is where I am, I have removed the two nuts at the wp and the nut at the manifold support to the back side of the compressor, I have removed the idler. AAAAAAAAHHHHHHHHHH!!!!!where is it, I know its got to be there??? :cry
Old Feb 13, 2002 | 05:03 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: OK,.....Where is it?????????? (vette87)
Theres a hidden torx bolt under the front of the compressor at the bottom.
Look at the A/C compressor pulley in front..see how it has a slot? Turn the slot where its down on the bottom at the 6 O'clock position and beneath there is a Torx bolt under the compressor you must remove...when the torx bolt comes out far enough,its slotted on one side and will have to align it with the compressor slot and get it out that way.
Its a PITA!!!
Careful not to strip this torx bolt, its a hard to find bolt and GM doesnt sell them anymore.
Old Feb 13, 2002 | 05:36 PM
vette87's Avatar
vette87
Default Re: OK,.....Where is it?????????? (Bill's86Coupe)
Ok now for the long shot, do you happen to know what the torx # is for it? :confused:
Old Feb 13, 2002 | 06:46 PM
David-F's Avatar
David-F
#40 torxs
David Fulcher
Old Feb 13, 2002 | 11:06 PM
vette87's Avatar
vette87
Default Re: OK,.....Where is it?????????? (David-F)
I don't have the bigger sizes of torxs, I guess it's time. Looked at them at Sears and they were 40 bucks for the large size set. :eek: That was for five or six of them. I guess if I'm gonna play I'm gonna have to pay. Thanks for the help all.
To OK,.....Where is it??????????
