Intermittent speedo problem
Old Jul 16, 2009 | 01:22 PM
Sliding's Avatar
Sliding
Default Intermittent speedo problem
I'm having some LCD speedo problems.
When I start to drive, I have 0 all the time. Then, as I drive,
speedo strats to jump from 0 to actual speed and back to 0.
As I continue to drive, I get more and more actual speed shown.
Then finally, after driving for 15 minutes or so, speedo starts to work
normally all the time.
Any idea what could be wrong?
Old Jul 16, 2009 | 04:41 PM
engle1147's Avatar
engle1147
Sounds like the sensor works any way.
The VSS may be coming out of the transmisson housing....get down and take a look...drivers' side rear portion of the tranny. Or the sensor's gear could be damaged. Some cars have a retaining bolt that holds the sensor some cars do not have the bolt. Check the wires and all the connections that travel from the VSS (vehicle speed sensor) to the cluster if you don't find other issues.
