Resonator Removal
Old Jul 17, 2009 | 03:19 PM
CAJUN C4's Avatar
CAJUN C4
Default Resonator Removal
Guys:
Anyone remove just their resonator from the stock LT1/LT4 Exhaust. I understand it really improves the sound quality a bit. Just a Tad Louder. Is this True?
Thanx
Old Jul 17, 2009 | 03:24 PM
aminnich's Avatar
aminnich
I replaced mine with a Magnaflow dual in/dual out muffler with the built in X-pipe. About the only difference I could tell was I lost 1/2" ground clearance and my wallet was a bit thinner. This was installed after I had already done the muffler delete and it changed the tone only very slightly. Altogether I would say I wasted some money.
Old Jul 17, 2009 | 04:10 PM
lt4obsesses's Avatar
lt4obsesses
Originally Posted by CAJUN C4
Guys:
Thanx
If your running the stock mufflers I would guess it pretty much be a tad louder inside the car. I think that is what the resonator was for. But if you went to a higher flowing muffler, I know some people replace it with an x-pipe or you could put straight pipes as there is a cross-over at the rear of the system.
I did the same thing Amminich did, but my experience was different. I really like the sound and the Magnaflow really helped to round out tone and all but eliminated that dreadful 2500 rpm low gear drone. But it is quite a bit more than a "tad" louder than stock.
Old Jul 17, 2009 | 09:36 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I friend of mine with another CE LT4 has cats, X pipe (no resonator and no mufflers) The vette sounds clean
Old Jul 19, 2009 | 12:27 AM
LannyL81's Avatar
LannyL81
Replaced the resonator with an H pipe on the '95; a Y pipe on the '96. Had Magnaflows on the '96. Could not stand the drone and replaced with LT1 outlets from Corvette Central. Much better.
On the '95 the daughter removed these mufflers and put the eliminators on...it is quite loud now......a bit fun to drive....but sure is loud. I'll be putting the LT1 mufflers back on.
If you like alot of drone....make that ALOT of drone, get the Magnaflows.
Old Jul 19, 2009 | 12:58 AM
PLRX's Avatar
PLRX
2017 C4 of Year
My 96 with the magnaflow performance exhaust it's very bad but that SOB sounds good
Old Jul 21, 2009 | 12:09 PM
CAJUN C4's Avatar
CAJUN C4
I think I'll either go with the straight Pipes or an "X".
Old Jul 21, 2009 | 01:37 PM
PLRX's Avatar
PLRX
2017 C4 of Year
This combo will give you no drone
Old Jul 21, 2009 | 01:46 PM
CAJUN C4's Avatar
CAJUN C4
Great That's what I'm after, In fact,my 84' with the stock LT1 Mufflers and gutted cats sounded inceredible. 60's Vet Sound with No Resonance what so ever.
I wonder how much the Resonator Restricts the Flow?
Old Jul 21, 2009 | 02:21 PM
runner140*'s Avatar
runner140*
They make some great X pipes now...these are magnaflows:
Old Jul 21, 2009 | 11:01 PM
Heckler45's Avatar
Heckler45
Had mine removed years ago and straight pipes put in, love the sound. mild when idle and reg driving, meaty beefy when on it.
Wondering if the X pipe makes any diff from the straight pipes? Any info?
Old Jul 22, 2009 | 01:00 PM
CAJUN C4's Avatar
CAJUN C4
I heard it makes it a little quieter and a lower exhaust note????
Old Jul 22, 2009 | 01:19 PM
CAJUN C4's Avatar
CAJUN C4
Also, I had an 84' with Gutted Cats and LT1 Stock Mufflers and I tell you it had the greatest sound. I got all kinds of compliments. I bet when I add the Straight Pipes it will sound similar.Not too loud,No Drone and just great sounding at WOT,
Old Jul 22, 2009 | 01:25 PM
CAJUN C4's Avatar
CAJUN C4
Check this Out
http://www.carcraft.com/techarticles...ion/index.html
To Resonator Removal
