how do you know if your headlight switch is bad?
Old Jul 18, 2009 | 02:48 PM
burmeister's Avatar
burmeister
Default how do you know if your headlight switch is bad?
i pull the switch out and the lights go up but they do not go down? i replaced the relays and still the same thing? im thinking its the switch how could i test it? thanks rob
Old Jul 18, 2009 | 04:58 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I think you just did.
Old Jul 18, 2009 | 09:03 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/Headlight%20Doors.pdf
Old Jul 19, 2009 | 03:20 AM
burmeister's Avatar
burmeister
thanks so i guess i need a new switch.. thanks alot guys
Old Jul 19, 2009 | 12:40 PM
josephf31's Avatar
josephf31
Default What year?
I may have one for '91 around here
Old Jul 20, 2009 | 04:41 PM
burmeister's Avatar
burmeister
my vette is a 86 it wont fit right?
Old Jul 21, 2009 | 11:05 AM
josephf31's Avatar
josephf31
Default I don't think so
but maybe someone else knows...even if it fit it might match the "coloring"...
Old Jul 21, 2009 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Did you replace all 3 relays ??
Did you follow the diagnostics in the link I gave you ??
Did the diagnostics point to the light switch ??
Old Jul 22, 2009 | 03:39 PM
burmeister's Avatar
burmeister
Originally Posted by agent 86
did you replace all 3 relays ??
Did you follow the diagnostics in the link i gave you ??
im going to print it out this afternoon and check it out agent. You are a great help.. Thanks ill let you know.. Rob
Old Aug 3, 2010 | 12:35 PM
OhioBob's Avatar
OhioBob
I know this is an old link but didn't want to start another one on the same subject. I got an extra headlight switch and need to bench check it for operation. Can I do an OHM check and what do I need to know if I can, i.e., switch on/off, what terminals to touch probes to, etc... Thanks.
To how do you know if your headlight switch is bad?
