Check the plug wires. Sounds like the distributor is off a tooth if the wires check out. Did you pull the distributor? ..If you did get a hold of timing light and unplug the ESC connector for the advance and see how far your off while someone cranks the motor. Or pull the distributor cap and kick the crank around to the "0" mark and see what you got for a rotor position.
Does SES light pop up when you turn the key to the on position without starting?
Did it run OK before?
Shure you put on the wires in the right order?
Yes, it lights up.
It ran very rich. The plugs were sooty. Gas mileage was poor.
Firing order and wire position have been confirmed.
The timing has never been disturbed, but... a connector just behind the distributor was disconnected, and from the accumulated dirt it looked to have been that way for some time. Is that the ESC connector?
Would have been good with some pics of the connector, but it sounds like the ESC connector, can you find a loose connector in the big harness under the wiper motor somewhere where it might fit in.
The ses light popping up and now codes showing up sounds worrying.
Don´t have a manual for a 88, but try and dis and re connect the minus cable from the batt. and see if that changes stuff.
Try locate the ESC connector in the big harness first.
OK, after locating the EST connector (the brown/black single wire connector near the brake booster), I disconnected it to check the base timing. It's set at 6 BTDC, spot on according to the emissions tag. So it appears not to be a timing issue.
The ECM wouldn't provide any codes at all - not even code 12 - so I bit the bullet and replaced it. The new one does display code 12, but has no other codes set.
For good measure, I replaced the O2 sensor. It was covered in soot.
Still it runs very rich, and won't idle smoothly (stumbles and dies).
I guess I'll take a look at the IAC and throttle body tomorrow. I hope to have something to report.
Fuel pressure was tested and was OK. 41psi at turn-on and 38-42 during operation.
I cleaned the throttle body and IAC valve today. It yielded the most improvement yet. Car now idles smoothly at 600-700 rpm and has better response. Still running rich though. I refilled the gas tank and reset the mpg computer. Drove a little around town and out through the boonies. Getting about 16 mpg so far, but mostly stop and go.
I need to get it inspected and take it for a longer run on the Interstate. There is a little stumble on acceleration. It just seems like it's not quite there yet.
After all you have gone through I would take a look at the plugs to see what there condition is, I would also recheck the TPS setting, and the timing to verified all was OK. Seeing as there is a little stumble on acceleration.
Timing is on, ECM seems fine with code 12, O2 sensor replaced. What about the plugs?
Have you reset the IAC yet? If you have a scanner, set it so that it is at 15 counts, give or take say 5 counts when the engine is in closed loop and warmed up. After that, adjust your TPS. When you are done, shut down and turn key to "Run" position. DO NOT CRANK. Use the scanner and see what the TPS voltage is at "idle". SLOWLY depress the gas and watch the TPS voltage. You want to see it rise smoothly. If not, replace TPS.
