Another Hooker 2149/2151 header question
I know they won't fit for AFR angle plugs, but would the port faces line up correctly on AFR L98 angle plug heads?
you will have no problems with the heads matching up. The only thing is they will not work with *AFR* angle plugs. The l98 angle ( as I have) and perfectly fine. I can't speak for the headers with EGR equip, but changing the plugs took ~15minutes opposed to 2 hrs with the original equipment! What a relief that is. I have pics of the ones without the smog crap. Let me know if you want to see them. Later.
