Superram, Excedrin, and Rogaine...
Old Jul 24, 2009 | 12:49 AM
Mark85Vett's Avatar
Mark85Vett
Default Superram, Excedrin, and Rogaine...
Ever put the whole shindig together and then realize you didnt route the OD cable under the Plenum?:mad ::bb
OK...that about covers it!
Old Jul 24, 2009 | 02:32 AM
pologreen1's Avatar
pologreen1
yup a couple of days ago, I just put the damn thing under the fuel rail, and had to unbolt it all. LOL I feel for you, I am sick of it already.
Old Jul 24, 2009 | 10:05 AM
cumbercr's Avatar
cumbercr
Don't feel like the Lone Ranger. I reinstalled all my TPI after an injector swap then realized I left off the MAP connector.
Old Jul 24, 2009 | 10:28 AM
Mark85Vett's Avatar
Mark85Vett
The worst part is that it's such a b!tch to get everything to line up, I used The Right Stuff on the runners (good luck gtting that apart), and I Loctited everything...so I forsee swearing a lot in my afternoon! I guess the good news is that I'm getting really good at dis-reassembly!
And I'm writing notes as I go so if I ever have to do this again, I'll have an easy reference...
Old Jul 24, 2009 | 11:25 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
There are advantages to having a manual trans
Old Jul 24, 2009 | 12:06 PM
Mark85Vett's Avatar
Mark85Vett
It's a 4+3...
Old Jul 24, 2009 | 03:20 PM
0Paul Ruggeri
Former Vendor
My 86 doesn't have a OD cable. Maybe its suppose to, but I have overridden the OD with a switch, so I don't need it.
Old Jul 24, 2009 | 03:27 PM
383vett's Avatar
383vett
On both ends of the runners, I have always used white, lithium grease. I silicone the gasket to the intake, and on the other end, to the top of the runners where the plenum seats. The gasket stays in place and the grease on the other side helps seal from vacuum leaks and allows me to reuse the gaskets indefinitely and makes for easy assembly and disassembly.
Old Jul 24, 2009 | 10:49 PM
Mark85Vett's Avatar
Mark85Vett
I had the foresight to order two sets of gaskets from LPE, and I'm glad I did...I goop the he!! out of it so I don't need to worry about any vac leaks...good to know the grease works; hopefully I won't ever take it apart....but AFR 195 upgrade could happen in a couple of years if I get bored with the 180's
Old Jul 25, 2009 | 09:48 PM
eguyett1985's Avatar
eguyett1985
I've always put my SR plenum and runner gaskets on without any sealer and never had a problem with any vacuum leaks. I did check all of my surfaces with a straight edge to make sure everything was flat, bolted it together and have been fine. I've had it apart a couple times and had no leaks ever. If you are going to use a sealer I would stick to Gasgacinch and make sure all of your surfaces are clean and flat.
Old Jul 26, 2009 | 01:56 PM
pologreen1's Avatar
pologreen1
that is what I thought, I might be asking for trouble,(and have to redo it) but I am trying it with grease on it, before I goop it all up, I would expect it whould seal, if torqued properly. My stock tpi crap was not gooped anywhere.
To Superram, Excedrin, and Rogaine...
