1994 Coupe 6spd - Mod 9 - code 62
I'm having a problem where once car reaches normal op temp. 190 Coolant, 205 oil temps, she dies.
I cleared all codes, stated car ran it for 15-20 minutes, she died, I checked codes and the only code that showed up was mod 9 - code 62
Then I tried starting, she cranked for a while, started ran and died right away. I checked codes and got mod 4, code 16... and the mod 9 - code 62. Car still at 190 & 205 respectively on temps.
Waited for an hour till temps came down - she started up and ran for about 20 minutes and it died.
OPti was replaced along with water pump, wires and plugs less the 3-5K miles ago... no leaks
