Help with compression ratio
Old Jul 26, 2009 | 07:19 AM
lt1396corvette's Avatar
lt1396corvette
Default Help with compression ratio
Hi,I'm in the process of changing my cylinder heads.Right now I have on the Lt1 heads and I'm putting on AFR 210CC HEADS.I have a 1994 396stroker with a big solid roller cam.When I built my motor I had the lt1 heads all done up and i have custom JE piston with 11.1 compression ratio.When I put on the AFR heads with the LT4 intake what will happen to my compression ratio.The AFR heads are 64cc. thanks jeff
Old Jul 26, 2009 | 09:02 AM
rodj's Avatar
rodj
Assuming the stock LT1 heads are 54cc , you are going to drop a heap of compression; down to approx 9.7:1
Going to need the heads milled down to reduce chamber size if you want to maintain CR.
http://www.wallaceracing.com/cr_test2.php
Old Jul 26, 2009 | 09:53 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
With the LT4 set-up, LLoyd Elliot milled my heads to 52cc. I was at 11.5:1
Old Jul 26, 2009 | 11:43 AM
Calderone's Avatar
Calderone
what happens if he lose that compression ?
Old Jul 26, 2009 | 11:55 AM
aboatguy's Avatar
aboatguy
For normal aspirated engines (if every thing else remains the same he will lose some horsepower)
However, increaing the static compression ratio can help tame a big hairy cam . So if he has a big cam it may end up with worse manners on the street.
For the original poster there are lots of good engine calculators that will let you know where you are at and predict where you will end up.
MIke
Old Jul 26, 2009 | 01:06 PM
lt1396corvette
Now if i was to put a supercharger on the car would that help. thanks jeff
Old Jul 26, 2009 | 02:21 PM
aboatguy's Avatar
aboatguy
Yes it would!
To Help with compression ratio
