headers
Old Jul 24, 2009 | 01:58 PM
383tpimachine's Avatar
383tpimachine
Default headers
HI im looking for some nice LT headers. I will be getting them JetHot coated so painted is prefered but I do not know which ones will fit IRON angle plugs
its going in my 85 c4
would like some below $350
if you have some that work or are selling some lmk
Old Jul 24, 2009 | 02:03 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Hedman Elites...Regular Hedman headers are "Disposable" like latex gloves.
Old Jul 24, 2009 | 03:25 PM
pologreen1's Avatar
pologreen1
Hedman Elites are like around $285-$300 on sale some places, I have been watching them also. As for the regulars, I have never had a car long enough to watch them rot out. I do see some people say they, last longer if not wrapped, because the wrap creates uneven temp, and moister.
Old Jul 24, 2009 | 05:16 PM
vader86's Avatar
vader86
I picked up a used set of TPiS, those will work with the straight plugs.
You will need boot protectors because the wires will rub on two cylinders though.
Old Jul 25, 2009 | 12:37 AM
383tpimachine
I have ANGLE plugs
and i called hedman twice with no answer
O well
will have to wait. I think my brakes are going out so its time to upgrade to BIG brakes
Old Jul 25, 2009 | 01:11 PM
M.J.L.'s Avatar
M.J.L.
Summit sells hedman elites for pretty cheap. You can get them thermocoated if desired...
Stay away from heat wrap. The advantages: Blocks heat
Disadvantages: possible fire hazzard, expensive, ugly, not greatly effective, rust, moisture, mildew, ect....
Old Jul 25, 2009 | 01:32 PM
383tpimachine
i cant find hedman elites uncoated is the problem
its what i really want since I like Jethot coatings
dont see any on summit uncoated
Old Jul 25, 2009 | 02:11 PM
M.J.L.'s Avatar
M.J.L.
I ordered some and then returned them. I needed the money for a unexpected disaster. I wish I still had the part #. Ill try to find it.
Old Jul 25, 2009 | 02:25 PM
383tpimachine
ouch man sry to here
but yea Im doing the c5 brake upgrade first since my pads are about shot
then it will be abnother 2 months for exhaust
383 nice cam HSR intake and dart heads but stock exhaust FTW
Old Jul 25, 2009 | 02:48 PM
M.J.L.'s Avatar
M.J.L.
Could always keep the stock exaust but just make it more effiecient.
Gut out the exaust manifolds, gut the cats(optional), and then use a plasama torch on the mufflers to gut them then weld em shut and spray paint them. No one will think it's got anything until it's to late. A sleeper!
But seriously, the stock exaust is going to hold you back a fair amount since it was designed for the L98. Like breathing thru a straw while running on the treadmill.
Old Jul 25, 2009 | 02:50 PM
M.J.L.'s Avatar
M.J.L.
Oh yea, your going to need to get the adaptor brackets. Jeffvette makes them. He used to frequent here but got banned. You can go here and find him. I hope it's not against the rules to post this link...
Click this link.
Old Jul 25, 2009 | 02:51 PM
M.J.L.'s Avatar
M.J.L.
and get slotted rotors but drilled have cracked under extreme conditions. For OEM rotors, go Napa. I have always used those and they great!
Old Jul 25, 2009 | 03:02 PM
383tpimachine
I found some nice baer drilled n slotted. Will they stand up to an autox every 3 months?
I found his site but didnt see any prices so i will check out that site
as for my exhaust its stock headers gutted cat and aftermarket post cat Y pipe since my stock one made its own cutouts
Old Jul 25, 2009 | 03:28 PM
c4cruiser's Avatar
c4cruiser
Summit has the full line of Hedman headers for L98 C4's. Use these Summit part numbers for lookup.
The Hedman Elites p/n HED-68448 have a thermal coating. It's a very good header and their coatings will last a long time. This particular header uses heavy 14 gauge tubes and a 3/8" flange. $392.95
There is another type of Elite header p/n HED-68446 that is ceramic coated but has 18 gauge tubes and a 1/4" flange. $346.95
Headman Street headers p/n HED-68440 are the painted version and are available at Summit Racing for $153.95. But these headers also use thinner 18 gauge tubes with a 1/4" flange.
JetHot is good, but why go thru ordering plain painted headers and spend a big chunk of change at JetHot when the Hedman coating is of very good quality??
Old Jul 25, 2009 | 03:43 PM
383tpimachine
i heard their thermal coat wasnt up to par.
i like them but i was going to get them in black not silver/chrome
To headers
