car won't start
They need 3 things....and 3 things only to run:
1. Suitable compression.
2. The correct mixture of fuel and air.
3. A suitably strong spark delivered at the correct time.
That's it. If those 3 conditions are met, they run. If one or more is missing or deficient, they don't run correctly or at all. See...isn't this easy?
Now...let's start with the simple stuff. Let's check and see if you have fuel pressure first, and HOW MUCH you have. On an 84, there is no schrader valve to attach a gauge to. You will need a T fitting and clamps...attach the T fitting just in front of the fuel filter, and run the hose to a low pressure gauge (0-15). Run 12V to the fuel pump terminal (G) on the ALDL to energize the pump full time. Tell me how many pounds of fuel pressure you have.
Checking fuel pressure on an 84 is a PITA. What I did on my 84 to check pressure is remove the crossover tube and have a port put on it (any hose and tube shop can make it for you), and a fitting on my low pressure gauge....it looks like this.
It beats the hell out of climbing under the car and using T fittings and clamps.
Anyhow....tell me how many pounds of fuel pressure you have and we will go from there.
You want to worry about relays and other stuff and you haven't yet found out if you have fuel pressure. If you found out first if you have fuel pressure, then you don't have to even consider fuel pump, fuel pump relay or anything else. Spark is the easiest thing to test so do that first, then measure fuel pressure. Cylinder compression is last. Post what you find and we will offer more help.
Even a cheap Haynes manual will show you how to check te relay. But you're much better off to buy the factory service manuals....check ebay for them.
I'm not sure the ALDL is the same as an 86 and newer, so you'll want to confirm that also, if it is you can simply run a wire from the positive terminal of the battery to terminal G on the ALDL, that will skip the fuel pump circuit and provide power directly to the fuel pump, if the pump is good it will run continously until the wire is disconnected.
ONCE AGAIN, see if someone with an 84 can confirm what I've stated...mines an 87.
PS. if your turn the key to the on position do you hear the pump run for a few seconds?
The ALDL is not a switch, it's a testing connector it's located on the bolster just above your right knee sitting in the car
http://www.corvettebuyers.com/c4vettes/codes.htm
In fact, about 3 years ago, my 84 had to be flatbedded back to my house. The car would start, run up to about 1300 RPM, and sputter. I could get about 15 MPH out of it. Being about 25 miles from home, I gave up and called a tow truck.
The fuel pump was running fine. Powered on for 2 seconds at key on, ran at engine crank and while engine running, and ran full time with 12V applied to terminal G on the ALDL. It was putting out sufficient flow to create about 5 psi, confirmed by my gauge.....and clamping off the return line and bypassing the filter changed nothing. No broken pulsator either.
A trip to the parts store for a new pump, and 30 minutes later it was running fine.
The moral of the story (I tend to ramble...sorry)...is to troubleshoot. Putting your ear to the tank while someone cranks the car will get you....well, dirty.
I'm not trying to be mean...really. I'm trying to help. Hook up a gauge to the pressure side, and run 12V to terminal G of the ALDL. If you have a fuel delivery problem up to the injectors, it will become apparent very quickly.
Keep us advised. If you lived within 20 miles, I'd have your car running this afternoon for the cost of parts and a case of Heineken.
He has an 84, so should have between 9-13 psi of fuel pressure. And on the TBI system, fuel pressure will bleed off within about 3 seconds of the fuel pump being shut off. It uses a simple bypass style regulator, and doesn't hold pressure at key off like a TPI system would. A leaky injector is extremely easy to diagnose on a Crossfire....you will be able to physically SEE it leaking. One of the few advantages TBI has over later systems is simplicity.
Correct again. It will run. That doesn't, however, mean the pump is good. A fuel pressure test will confirm if it is healthy or potentially infirm.
