I have a 94 coupe. The power set selector switch located on the console has to be replaced.
Is there a way to get to the wiring harness under the console without removing the seat and the knee bolster?
Can I remove the console compartment without removing the boplster and the seast?
pretty sure you need to remove the console to get to that switch, even if you didn't have to it will make the switch replacement much simpler. It's not really that big a deal to pull the seats and console out to get to the switch.
