Can you do without the egr valve on an 85 without it throwin a code? Also what is the little wire that is attatched to the egr valve? The wire bung broke while i was workin on a project and if i can do without the egr valve im just going to remove it. Thanks ahead of time!
i removed mine on my early 86 with no issues, should be the same on yours.
really?? We can just take it off? I have an E86, and I want the EGR off just to get it out of the way, its a PITA trying to do anything on the pass. side of the engine. To the OP, I think the wire is the EGR sensor that runs to the ECM.
